Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#3571
#3573
I got a set of coupe oem 19s for my 05 sedan, the tire specs are:
front:
Offset: +30mm
225/40ZR/19
rear
Offset: +33mm
245/40ZR/19
I'm going to lower the car with coilovers enough to close the fender/tire gap. i already have rear camber kit only.
my questions:
1. Do i have to get a camber kit for the front?
2. Do i need to roll rear fenders?
front:
Offset: +30mm
225/40ZR/19
rear
Offset: +33mm
245/40ZR/19
my questions:
#3574
front:
Offset: +30mm
225/40ZR/19
rear
Offset: +33mm
245/40ZR/19
my questions:
front:
Offset: +30mm
225/40ZR/19
rear
Offset: +33mm
245/40ZR/19
my questions:
it...
2. You won't need to roll fenders unless you get thicker tires.
#3575
I am looking at getting a set of rims and tires for a great deal if they will work on my car. The rims are on a 350z so I am sure the wheels will be fine but I am concenred about the tires.
They are Nitto nt555. Extreme ZR...
Front... 245...35...ZR20... 95w
Back... 275...35...ZR20... 102w
Rims r staggered... Front, 20x8..5 back 20x10
Will this work on a 2003 G35 sedan? I am concenred the rear tire is too big :/
#3581
What are the offsets front and rear? Tire sizes are fine, but you'll need offsets around +25 front and +40 rear. Where as Zs run +15 +20
#3582
#3584
I don't profess to knowing everything about wheel offsets, but I'm running close to your set up. 255/35/19 9.5 +12 fronts, then 295/30 rears 10.5 +22. Tires are michelin ps2's on BC coils, running close to natural camber around -2.5 or so with rear camber arms installed. Rears needed to be rolled, fronts need to remove bolts and depending how low you are the fronts need to be rolled too. I test fitted a 305 tire in the rear and it didn't work, fender work or more camber would've been required. So that should give you an idea for your +12 rears. Hope this helps.
#3585
Blain, (I cruise the forum a lot so I hope it's not creepy I know your name haha) do you think you could give me some advice on a wheel set up? I am seriously considering picking up a set of wheels, but am only holding back waiting to hear back from a few people on the fender work and modifications required to fit the set up. The rears are 20x12 -4. In an ideal world (being as frugal as possible) I would run a 285/30 that's already available to me. Would it be possible to pull the fenders enough so I wouldn't have to run retarded camber and could run the 285/30's? I'm trying to stay away from ridiculous stretch on the tires because local shops here had trouble even mounting a 255/30 on an 11". Adon's ride has been giving me a pretty good idea of what to expect, and I thought I read he was running a 285/30 or a 275/25. Thanks in advance.
