Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#4262
Recently I have found myself falling in love with the Volk GT-S wheels and while searching on Ebay for a beater winter set up (I hate the stock 17s) I came across the Vertini Dust wheels. They look like GT-S reps, am I correct in thinking they are. Checked out their website and they don't say what the wheels are... Forged? 1 piece cast? 2-3 piece? At 400-500 a wheel I would hope they are more than just pretty 1 piece cast reps. Anyone have any knowledge or experience with these?
#4263
#4264
But the wheels will fit fine, I'd recommend rolling the fenders just to be safe.
#4265
#4267
Recommended wheel tires sizes in 20s? Looking for semi aggressive setup. And I'm slamming it.
Here's what I currently have. 05 sedan on BC coils, SPC rear camber, rolled f/r fenders, 19x9.5 all around TSw Londrina chrome +15/+10 with 225/35.
Thinking of 20x10/11 in +15/+25 with 225/235 30 tires. Suggestions? Thanks in advance.
Dcampos662 (09-17-2012)
#4268
1. 235/30 on an 11 is going to be pretty retarded
2. Specs won't match aggressiveness.
To make these look right this is how I'd set it up.
Front
20x10 +15 with a 5mm spacer (making it +10)
225/35
natural camber from slamming the car should put these right outside the fender with enough movement to clear, if not I would recommend front camber arms. This is to make the front match in aggressiveness to the rear)
Rear
You're going to get stuck here.... you will need a spacer to clear the strut and a pull to allow the spacer. 20s make camber an issue as the wheels are much taller than 18s or 19s.
20x11 +15 (with spacer)
245/35
-6 degrees of camber (you may need to switch to battle version camber arms to achieve -6 degrees)
and then the rest will need to be done in fender work.
You may be able to pull it off with 20x11 +20 and -5 degree but you will need a lot more pullage....
#4269
So i just bought some wheels for my 06 g35 coupe. Wheel specs are 19x10+9 in the front and 19x11+20 in the rear. I was thinking of running 235/35/19 in the front and 255/35/19 in the rear. What tires do you guys recommend? I've been looking at falkens and yokos.
Thanks
Also i forgot to mention I am lowered on fortune auto coilovers and still have a spc camber kit and spl toe arm to install with all this.
Thanks
#4270
For a 19x10.5 30et rear on my sedan, what would be ur suggestion for a good set of camber arms? Also, as far as tires go, what would u suggest as far as Nexen n3000, Achilles, Nankang NSII, or Federal 595's? Id rather go with a directional budget tire because I can eventually flip them and dont see the point of running $1000 worth of tires that will get camber worn. I know the Federals run wide, and the Nankang small. For size 265/30's, or 245/35's or would another size be more appropriate? I think Marcus is running a 245/35, so I assume it would be comfortable for daily use?
Thanks for the help, just wanna make sure I get it right the first time.
#4271
Thanks
Thanks
Marcus doesn't his daily car and he runs Yokos, so not sure what comparison that is.
Nankangs or achilles are your best bet. 245/35 will be optimal for ride comfort due to the larger sidewall but 265s will mount and be removed much easier.
#4273
I'm trying to figure out a better setup for my 05 G35x sedan for next year.
I'm thinking 19x9.5 +12 all around 245/40/19
On Bc racing Coils 25" fender to ground all around
Spc camber kits w/ toe bolt Front and rear
Rear fenders rolled
Can you point me in the rite direction for flush/semi aggressive/willing to run a mild stretch if needed setup =)
Looking to the future as my 18x8.5 +25 1.3 camber front 2 degree camber rear rite now just isn't doing it for me, I think 19's and a bit wider will look alot better on my ride.
Trying not to run more then 3 degrees of camber.
My ride currently, pic was taken before it was settled.
Rear fenders rolled
