Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#4396
hey i just got my new wheels for my 2005 g35 sedan in and just a few questions
here are the specs:
vossen cv3
front
19x8.5+32
rear
19x10+38
also just got my coilovers and rear camber kit
i have NOT installed wheel, coilovers, or camber kit yet, i want to do it all in one shot
now for question:
-which tire sizes are best for me? i would like to have a stretch tire, considering that i will lower the car
-i am going to get my rear fenders rolled, would i have to pull my fenders?
-is there anything else i should be worried about? rubbing issues?
i cant wait to get this setup on my car!
thanks!
here are the specs:
vossen cv3
front
19x8.5+32
rear
19x10+38
now for question:
thanks!
If you want to stretch, you're going to need spacers....
Run 225/35 and 245/35.
Run 15-20mm spacers in the front (depend how low you go)
Run 15mm spacers in the back.
You will need to roll the fenders but a pull is not required.
#4397
It will look stupid for multiple reasons.
1. 10.5 +0 will poke... therefore you're going to have tire out of the fender
2. 305 hangs over the edge of a 10.5 and reduces handling
3. 18s and no drop look generally bad.
You're going to need a 265 on the back to keep the tires under the fender.
#4398
#4399
Preferably no camber more than 1.5-2 , I do have over fenders but really don't want to go that route cause I wanna keep the stock sexy lines of the G. Thanks so much!
#4400
#4402
well you can't stretch anything on the front because it is too thin.
so then if i didnt want to add spacers which tires sizes would i then use, keeping in mind that i will lower the car?
thanks agian!
#4405
#4406
blain ive been meaning to ask you what you think these offsets are? no spacers.
suppose to be 19x9.5+22 19x10.5+17. <this might be the true offsets.. I'm thinking the Xs have different clearance than RWD bc of this https://g35driver.com/forums/media-s...-steplips.html and gtz1stballer92 has an X +18 in the rear and tucks... < this.. https://g35driver.com/forums/g35-sed...e-specs-4.html
#4408
#4410
Hey guys-
A few important questions
.1 I have rims and tire size Stock 18" ON MY 04 coupe with brembos- What other size rims will the tires fit on? Like width and such?
2. What offsets will fit on he coupe with brembo without having to roll fenders and get camber kits?
So basically what im sayin is, i am looking at aftermarket 18. id like to use my stock tires as they are almost new, but im not sure what size 18's will fit my tires,and fit the coupe over the brembos.
I will be selling my stock 18's
Please please help me guys i want to buy in the next few days!
