G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   Falken 452's 2007 Sedan (https://g35driver.com/forums/wheels-tires/292125-falken-452s-2007-sedan.html)
Xanlith Jun 9, 2009 02:50 AM
Been reading through this forum for about two hours and have been seeing quite a few opinions on which brand and model of tire everyone likes. Thankfully my decision was made on those two criteria for me when I had my rear passenger side stock tire go flat today. The only thing I could find locally in 245/45/18 was a Falken 452. So now I'd like to pickup a set of Falken 452s for my fronts next week but unfortunately the 452's dont come in 225/50/18s.
I'll be the first to admit that I've never owned a car long enough to have to replace tires so I have no clue what I can change measurement wise when replacing a tire. I love my G35 though and am most likely going to buy it out when the lease is up so its time to learn. To keep a matched set, my only options up front that seem reasonable are the following:
225/45/18 - (Slightly smaller, spedometer ~2mph slow)
245/45/18 - (Touch smaller, spedometer ~.5mph slow)
I've heard matching the fronts with the rears will mess up VDC though. Is that true? If so will the 225/45/18s mess it up as well? Would it be better to get a different brand and model up front to keep my stock sizes and keep everything working properly?
Thanks for your advice, I definitely have alot to learn.
soundmike Jun 9, 2009 08:40 AM
I don't think matching, as long as the overall diameter is the same, will mess up VDC. I have a non-staggered set-up on my Sport.
You may be able to get away with 245/45 in the front, but check Falken's tire specifications and make sure it's safe to mount it on your front rims, which i'm assuming is 7.5" wide.
Xanlith Jun 9, 2009 09:08 AM
Thanks for the post soundmike! It looks like Falken's approved rims are 7.5" for the 225s and 7.5-9.0" for the 245's so looks like the 245s are doable from a rim standpoint.
Xanlith Jun 9, 2009 06:03 PM
Any other advice from the experts? Im still struggling with which direction to go. Seems like the 225/45s would be a more aggressive change than the 245/45s but I really love going around corners fast and want to avoid messing with my VDC.
The 225/45s change my diameter -7/10" and the 245/45s change my diameter -2/10". I think the only other real concern I have keeping me from trying the 245/45s now is that Im putting a much wider tire on a 7.5" rim. If thats not an issue I think Im going to go with the matched tires and hope for the best.
Thanks in advance.
© 2026 MH Sub I, LLC dba Internet Brands
