245/35/20's rubbing in front
Anyone running 245/35/20's in on their G35 Coupe and having rubbing issues? Mine are rubbing when I hit big dips and I'm wondering if anyone cut or removed the plastic from inside the fender. Any help would be greatly appreciated!
My car is lowered with Eibach springs
Your running the wrong tire size..You should be running a 245/30/20
Yep, your tire is an inch taller than stock. Switch to 245/30/20 or 255/30/20
Crap, I was hoping you guys wouldn't say that. I like the way the 35's look because it fills the gap VERY nicely and I was hoping I could get rid of the rubbing by possibly removing or cutting the plastic inside the fender. Are there any consequences to removing the plastic?
Using taller tires to fill wheel gap FTL
hilarious.
+1
245/30/20 or 255/30/20 will solve your problem. Drop your car more to fill up the additional fender gaps. |
I didn't pick the tire size, the tire shop recommended this size to me unfortunately. I have no problem lowering the car to fill the gap although it is pretty low already with the kuruma bumper
Any recommendations between the 245/30/20 and 255/30/20?
My rim size is 20 x 8.5
245/30
^lol
Originally Posted by lsvtecg35
(Post 4320009)
245/35 isn't the correct size, but people run it anyway for looks. I have 245/35s up front, am lowered on 350z Htechs, have -1.25 degrees of camber (SPC kitted), and don't rub. I've heard of a few people that have rubbing issues with this set up, but not so many that it would scare people away from it.
| All times are GMT -4. The time now is 08:22 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
