G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   can't get brake dust off gram lights! (https://g35driver.com/forums/wheels-tires/299182-cant-get-brake-dust-off-gram-lights.html)
HXS Jul 25, 2009 07:41 PM
i know lips are very sensitive so i only tried soap and water. no luck.
just hoping anyone here can gimme a solution!
http://i29.tinypic.com/29p9erm.jpghttp://i30.tinypic.com/2644a40.jpg
JBF Jul 25, 2009 07:46 PM
try meguiars mag polish...the pink stuff.
mine were trashed and I used that stuff with a little elbow grease and some poor boys wheel sealant
redlude97 Jul 26, 2009 02:40 AM
Try a mild claybar and lots of lube. If it etched into the metal though you'll have to strip the anodizing and repolish with a metal polish
j 4 lD Jul 26, 2009 02:54 AM
Try some wheel degreaser/cleaner.
http://ecx.images-amazon.com/images/...A280_SH20_.jpg
You wet the wheels first with cool water, spray the degreaser, let it sit for 30 seconds to a minute, and then scrub away. If the dirt/grime doesn't come off, then you need to try some of the other suggestions. This helped me get stains off of my wheels that I couldn't remove with soap and water.
HXS Jul 26, 2009 05:07 PM
thanks for feedback guys. will try above recommendations.
EL-EE-ES Jul 26, 2009 08:35 PM
arent gram lights anodized? if so then you cant use a polish on them
JuicedAthletics Jul 27, 2009 09:35 PM
Be careful with any cleaners. I used a "safe for all wheels" cleaner on my J8s and now my annodized lips are in need of a new polish.
Poorboys makes some wheels cleaners for metal specific wheels.
lovemyg88 Jul 28, 2009 03:59 AM
Seems like you did not use wheel sealant. I have no ideas on how to remove those brake dust since I always apply wheel sealant to my wheels and it helps a lot in protecting your wheels from brake dust. Make sure you apply a coat (1 coat is enough) of wheel sealant to your wheels after you are done washing it. And brake dust will not be a problem again. Im using Poorboy wheel sealant and it is great.
elayman Jul 28, 2009 04:03 AM
^ I bought that stuff too and I feel like it doesn't do anything, brake dust sits on it just the same as when I don't put it on, and it's a pain to put on with so many spokes, how do you apply yours?
lovemyg88 Jul 28, 2009 03:30 PM
^true, it is a pain to remove the sealant but the sealant works great. Brake dust still sits on it. But it is much easier to remove the brake dust. You can test it by using your finger and wipe off the brake dust, brake dust will come right off.
HXS Jul 28, 2009 10:27 PM
so i tried claybarring (with LOTS of lube) almost everything i can get on the lip. then i polished with this incredible product:
http://ep.yimg.com/ca/I/classic-motoring_2061_21134532
i'm telling you it does wonders :)
for those of you wanting to try this method, don't be scared after claybarring if the lip becomes hazy. mother's billet polish will clear it right up :thumbup:
http://i31.tinypic.com/20s9086.jpg
vq35dedriver Jul 29, 2009 12:17 AM
OMG thats some nice stains you got there
you gotta stay on top of that good luck getting it off
JBF Jul 29, 2009 06:31 AM
Hmmm(prolonged beard stroke)
I'm intrigued by this mother's polish!
TimW Jul 30, 2009 04:10 PM
those lips are anodized, same as Volks.
http://www.hrewheels.com/hre_in_acti...nd-wheel-care/
Metal Polish is a *last* resort and assumes you've given up on the anodized finish.
gcoupe_toronto Jan 14, 2010 06:34 PM
I was thinking of using the Meguiars or mothers clay bar is this safe (mild enough) to use on chrome wheels?
http://www.lhautodetailing.com/produ...sSSClayKit.jpg
© 2026 MH Sub I, LLC dba Internet Brands
