G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   Tire sizing for OEM 18's (https://g35driver.com/forums/wheels-tires/302967-tire-sizing-oem-18s.html)
milky Aug 19, 2009 07:40 PM
Hi all,
Just had a quick question. If i have OEM 18's, would it be alright to use the following tire sizes?
235/40/18
265/35/18
I know stock uses 225/45 and 245/45, so it'll be slightly wider in the front and more wide in the rear, would this be okay?
Thanks for the input/suggestion.
4mermarine Aug 20, 2009 11:18 AM
I'm getting coupe 18's and will be running 245/45's all the way around... Gives you just a tad bit more meat.
Go to: http://www.miata.net/garage/tirecalc.html
Punch in your tire sizes to see the difference... It really helped me decide.
shishidosan Oct 27, 2011 10:54 AM
im looking to replace tires and was looking to run the same set up. how has this worked for you?
4mermarine Oct 27, 2011 11:18 AM
I ended up going with the 235/45/18 instead after doing more research and forum searching. Just seemed like a better fit with the least chance for rub since I'm lowered on Z/G springs. Glad I went with that size for sure.
shishidosan Oct 27, 2011 11:41 AM
what did u go on with on the rear? im stock with brembo calipers. so i was looking to see what was the widest width i could with in the front AND rear with the OEM 18". on another post, someone said they wouldnt go wider than 245 which i agree since its only 18x8.
im also trying to find a post on which brand tire to with with these 18s. im not planning to go aftermarket on anything. i just want max tire life without messing with the suspension..
4mermarine Oct 27, 2011 11:59 AM
I didn't want a staggered setup so I could rotate and just decided that 235's were a better fit for my preferences. From everything I've read the 245's will work. I searched the forums for weeks looking at the differences and the way it looked with being lowered, not lowered, slammed, etc... You're down to personal preference at this point.
If you aren't lowered then you should have to worry about any uneven tire wear. Tire choices run the gamut for the coupe 18's. I went with Falkens but I don't think I'd by them again. I'm getting SPC front camber arms installed tomorrow to deal with the uneven tire wear I'm getting in the front from being lowered.
shishidosan Oct 27, 2011 01:31 PM
cool. thanks! now to find the tire...
© 2026 MH Sub I, LLC dba Internet Brands
