Official Wheel Fitment Pic thread{PICS&SPECS ONLY}
  #241
Old 03-23-2017, 09:20 AM
Nixkguam's Avatar
Newbie needing knowledge
This is my first set of aftermarket wheels and I need to buy the right set of tires asap.
  • 2003 Coupe non-brembo
  • Suspension: 1" drop BC br coilovers
  • Wheels: Cosmis MR7 18x10 +25mm front and rear
I've read and read and still can understand all the numbers. So can someone help me? I want to buy the biggest widest tire I can fit without rubbing
Thanks in advance for all tips, pointers, and advice
  #242
Old 03-24-2017, 07:27 PM
Mr. Brooks's Avatar
Thumbs up
That joint is nice
  #243
Old 04-22-2017, 07:07 PM
Aaron05G35's Avatar
2005 base with 20x9 +20 front and 20x10.5 +25 rear.
Enza vatore wheels and 245/30 f and 275/30 rear forgiato tires.
  #244
Old 04-23-2017, 01:15 AM
Mr. Brooks's Avatar
Thumbs up
I've read and read and still can understad all the numbers. So can someone help me? I want to buy the biggest widest tire I can fit without rubbing
My rears are 20x10s with a plus 20 off set. The widest tire I've put on my car without rubbing is a 295-30-20.
  #245
Old 05-08-2017, 12:25 PM
DaltonSR20DET's Avatar
Advan Racing RG-D 19x9 Square set up
2005 G35 Sedan 6MT Sport
BC Type-BR Coilovers (Front = true coilover / Rear = BC adjustable strut with separate adjustable perch for sprint), SPC front upper control arm, SPC rear camber arms, SPC toe bolts. Camber all around = -1.8 to -1.9.
Body modifications = Just rolled the rear fenders.
Wheel = Advan Racing RG-D 19x9 +25 all around, "Square" set up.
Tires = Front = Bridgestone G-Force sport comp 2 (255/35/19)
Rear = Falken ZIEX ZE950 (255/35/19)
Well, it sits pretty and I can drive around town but even little bumps on the road around town at 25-35mph, it'll rub. Either in need to dial in more negative camber, slightly pull the fenders, run a more narrow tire (225's or 235's especially for the front), or all of the above.
  #246
Old 05-09-2017, 12:33 PM
Mr. Brooks's Avatar
^^^ have someone trim away the inner lip that everybody gets rolled. It looks better and when done correctly, you can't tell it was done. That's what I did. Now, no more rubbing in the rear and I'm wearing 285-30-20s. Your car looks good by the way.
  #247
Old 06-24-2017, 11:53 AM
darneld's Avatar
Trying to put 370Z Wheels on an 03 G35 Coupe, shop says they won't fit. Suggestions?
  #248
Old 06-27-2017, 04:52 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Which 370 wheels? Post up the sizes and offsets and we can help you figure this out. If you can't find the specs we won't have a clue.
  #249
Old 06-29-2017, 10:46 AM
darneld's Avatar
Not sure
They Enkie on the back? I assumed they were OEM, maybe not?
  #250
Old 07-11-2017, 06:37 PM
370z Wheels
I think the Enkei's belong on the Base model. The Sport and Nismo 370Z have wheels manufactured by Rays.
Base:
18x8 +43 front, 18x9 +15mm rear
225-50-18/245-45-18 Yokohama ADVAN Sport
Sport:
19x9 +47 front, 19x10 +30 rear
245-40-19/275-35-19 Bridgestone Potenza
NISMO:
19x9.5 +40, 19x10.5 +23
245-40-19/285-35-19 Yokohama ADVAN Sport
  #251
Old 12-20-2017, 12:56 PM
deeliciousqueen's Avatar
G35 coupe 6mt
Originally Posted by DaltonSR20DET
NISMO:
I am planning to do 295/30r & 265/35f with these nismo, I am currently dropped about an inch on my coupe and rears are rolled, will there be rubbing issues and will it fit?
911Turbo
19 Inch
08-24-2016 08:31 AM
BlackGee35
07-31-2015 11:04 AM
IEMaestro
20 Inch
07-30-2015 04:30 PM
Soumilg
07-18-2015 12:33 PM
Quick Reply: Official Wheel Fitment Pic thread{PICS&SPECS ONLY}
