VMR V710's with wobble lug bolts
I've always been in love with the design of the VMR V710 rims. I was just wondering if 19" VMR V710's (5x112 bolt patterns) will fit on a G35 when using the wobble lug bolts. I found wobble bolts that state it is possible to put 5x112 rims on a 5x114 vehicle. Thanks in advance :)
Wobble lug bolts: http://www.lakeshorewheelandtire.com...n=item&id=2889 VMR V710: http://www.velocitymotoring.com/wheels_v710.html |
you can have them custom bored to the correct bolt pattern, just contact VMR directly.
hopefully you can find some decent offsets for your coupe .. i think all VMR offsets are kinda high .. due to the fact they are made for BMWs
You're forgetting that our cars dont use lug bolts.
I saw pictures of them on a sedan the other day. They have offsets in the 20's, I'd love a set of 18x.8.5+20 for winter use, that be hot!
http://i480.photobucket.com/albums/r...464_408759.jpg OP should contact them to encourage them to set up a group buy, they'd probably sell like hotcakes and expand their market a little more. |
Originally Posted by idrive_MD
(Post 4824429)
apparently a Z guy said he was quoted $75 per wheel to get them drilled with the proper bolt pattern. That brought his total to $1350 after shipping for a set of 18's, Forgestar has a similar wheel with more size/color options for about the same price if not a little less.
why don't you get these wheel adapters?
they'll work only if you get at least a 25-mm width spacer. kill 2 birds with 1 stone :) (weak offset and different hub pattern) |
Originally Posted by xfuz1on
(Post 4831085)
that is hawtt
Here's some more pics. http://i480.photobucket.com/albums/r...0/a44bf48c.jpg http://i480.photobucket.com/albums/r...llingshots.jpg http://i480.photobucket.com/albums/r...lingshots2.jpg http://i480.photobucket.com/albums/r...0/IMG_0769.jpg http://i480.photobucket.com/albums/r...0/IMG_0766.jpg http://i480.photobucket.com/albums/r...464_408758.jpg http://i480.photobucket.com/albums/r...464_408758.jpg |
Originally Posted by Igor1080
(Post 4852998)
:thewave: Thats my car. Kinda funny you guys have a thread about these wheels. I have the only non german car to have these wheels on in the entire U.S. I got them custom bored directly from a company that works with VMR. They're called supreme power parts, this guy Jeff helped me out and he did a very good job. If you have any more questions I'd be happy to answer them.
(Post 4853141)
How much did the custom VMR rims run you ?
Igor, what offsets did you get?
you bother weighing them at all before you had them mounted?
Originally Posted by SDGenius
(Post 4854237)
(Post 4855566)
rims are clean
| All times are GMT -4. The time now is 08:26 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
