would these 19x10+13 front and 19x11+0 rear fit on 05 g35 coupe?
Old May 4, 2010 | 11:42 AM
lakerschamp2000's Avatar
would they fit on a g coupe without heavy mod? my fenders are rolled but no adjustable camberkit. my car is about 2" lowered.
Old May 4, 2010 | 11:52 AM
bjquinnIUmed's Avatar
you'd need a camber kit front and rear, b/c you'd have to run some serious neg camber to make those fit.
If you're already lowered 2 inches and have no existing camber/toe adjustment your tires aren't going to last very long.
Old May 4, 2010 | 12:04 PM
idrive_MD's Avatar
The fronts I wouldnt worry about too much, clearance will be more effected by whatever tire you choose. The rears, will need some negative camber, so I suggest you suck it up and get a rear camber kit. I had 19x10+20 with 255/35/19 tires with lots of room left to spare with friendly camber settings on stock arms. In the rear I was 19x11+20-ish with 295/30/19 with SPC camber/toe kit. Needed a roll, almost a poke, so your rear set up will need some mor enegative camber to bring it in some more. I'm going with 285/30/19 on the fronts and 305/30/19 for the rears on the same size wheels, hopefully this week .
Old May 4, 2010 | 12:15 PM
thanks for the help guys, i will be running with these tires spec
225-45-19 front
245-40-19 rear
so do i need to run neg camber with these stretchy tires?
Old May 4, 2010 | 01:20 PM
GR6RR's Avatar
I run a 10.5 +0 on my rear, 245/35 tire. I got natural camber, no kits...
Old May 4, 2010 | 01:41 PM
idrive_MD's Avatar
with tires that small I doubt you'll have a problem other than holding air! probs wont have to run crazy camber as well.
Old May 4, 2010 | 02:03 PM
what tires size?
Old May 4, 2010 | 02:20 PM
nghiars's Avatar
^^the tire specs you posted in post #4.
Old May 4, 2010 | 02:51 PM
did your fenders roll or not?
Old May 4, 2010 | 05:20 PM
GR6RR's Avatar
i got rear rolled...
before I got it rolled, I had test fitted them and tried to exit my driveway.. rubbadubdubb it was...
had it rolled by ShanesG and its all good now...
no camber kit, all natural camber...
Old May 4, 2010 | 06:12 PM
cool thanks bro, shanes gonna roll my fenders today and hope they wont rub haha
Old May 5, 2010 | 03:21 PM
208G35's Avatar
do you have any pics. I would like to see what it looks like with the 245 on a 10.5 rim.
Old May 5, 2010 | 06:31 PM
GR6RR's Avatar
Right here buddy!
https://g35driver.com/forums/picture...ost-em-up.html
you should hang out in there for some time..
also try this https://g35driver.com/forums/search.php
Helps me out alot...
Old May 6, 2010 | 12:10 AM
illest's Avatar
Get a camber kit and save yourself time and tires!
Old May 8, 2010 | 09:50 AM
jasony0228's Avatar
any pics update?
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
djreinx
Jul 13, 2015 05:04 PM
