G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   Tire Pressure for aftermarket 19's? (https://g35driver.com/forums/wheels-tires/34874-tire-pressure-aftermarket-19s.html)
neffster Oct 11, 2004 08:44 AM
What would the proper tire pressure be for a 19" tire? I know the stock pressures are 35psi for the 18's and figure the common sense thing would be to INCREASE the pressure of the 19's (since the sidewall has decreased).
Does anyone know what tire pressure TOYO recommends for a 255/35/19 and a 275/35/19?
G35pm Oct 11, 2004 12:49 PM
Re: Tire Pressure for aftermarket 19's?
I put mine at 35psi for my Volk GT-7 19in. I have Toyo T1-S tires. I read somewhere either on the rim labels or the tire labels that you should fill them up to the recommended vehicle tire pressure. Can someone correct me if I'm wrong?
NIFG35 Oct 11, 2004 06:23 PM
Sup,
I'm running 245/35/19s and 255/35/19s Toyo T1-S and tire pressure is at 40 psi. Whatever Infiniti recommends is sorta thrown out the window after going +2 sizes (from 17's to 19s). I wouldn't run anything below 40 and check the tire pressure about every 2 weeks.
NIF
G35pm Oct 14, 2004 02:48 AM
anymore input on this?
neffster Oct 14, 2004 05:28 AM
no kidding. I figure 2/3 of the regular posters on this Wheels, Brakes, Tires and Suspension forum have aftermarket 19's or 20's. Come on ladies, hook a brother up.
I even sent an e-mail in to Toyo and they haven't responded. WHA'S UP WIT-DAT?
av8r Oct 14, 2004 09:00 AM
You should consider asking infiniti what pressures they are using on the 2005 coupe with 19s. That would be the most accurate I think.
IMO if you are worried about bending a rim, increase the pressure. I have always run at about 40psi for this reason.
04' Sedan 6MT /Premium/Aero/HuperOptik/XM
Z-Tube / Stillen- Sways, Airbox & Grounding Kit
19x8.5/9.5 Hiros / S-03s 245/40 & 275/35zr19
Tokico D-Specs, 350z H-Techs, Kinetix Camber Kit
Buddha Oct 14, 2004 02:25 PM
the general rule is + 1 psi for every size up
04 G35C 6mt/aero kit/nav/premium
TINMAN Oct 14, 2004 02:42 PM
i would go with the recommended psi on the tires that you have.
https://g35driver.com/rides/spec/pix...1081215953.jpg
© 2026 MH Sub I, LLC dba Internet Brands
