G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   Aggressive oem 19's (https://g35driver.com/forums/wheels-tires/349072-aggressive-oem-19s.html)
Frankieg35 Aug 27, 2010 09:58 PM
Aggressive oem 19's
I have a coupe and plan on running oem 19's with spacers and a stretch for winter.. What size spacers and tire size should i run??
kennymo Aug 27, 2010 10:07 PM
35mm
Frankieg35 Aug 27, 2010 10:08 PM
Front and rear?? What size tires.. How wide are the oem 19's??
akk08 Aug 27, 2010 10:33 PM
25mm front 35mm rear
Frankieg35 Aug 27, 2010 10:36 PM
I dunno if the 25mm in the front will be enough..
caketech Aug 29, 2010 08:59 AM
if you want a bigger stretch maybe 215/40 19 fronts and 225/40 19 in the back.
and i'd use 30mm front and 35 rear for spacers.
akk08 Aug 30, 2010 11:33 PM
i have 215 35 19 tires a pair brand new...but your not going with oem 19"s anymore so delete this thread lmao.
akk08 Aug 30, 2010 11:34 PM
you should do 35mm front and 50mm rears just slap two 25mm spacers together lmao...
XiN Aug 30, 2010 11:35 PM
Frankie,
19x8 +30 F
19x8.5 +33 R
Hope that helped you.
tnmt_donkey Aug 31, 2010 12:18 AM
Did you guys install long bolts and use longer open end nuts?
I have 15mm on my front and rear. I am always afraid that the nuts would fall off.
Xet Aug 31, 2010 12:29 AM
Wait you are running 15mm spacers without extended stud or hubcentric with built in studs???? If so I would suggest you don't drive again until you correct that, just search and you can find threads where people's wheels literally fell off while driving due to running spacers without proper studs, and that was with spacers much smaller than 15mm.
driver1712 Aug 31, 2010 01:52 AM
the title is an oxymoron... "aggressive OEMs"
Beebo Aug 31, 2010 03:28 AM
wait you want spacers and stretched tire for winter? :eek:
JBF Aug 31, 2010 03:47 AM
OP you can run 35mm R and 30mm F with stock tire sizes and still look somewhat aggressive.
I did for months :D
Beebo Aug 31, 2010 03:50 AM
you guys are ****ing crazy
© 2026 MH Sub I, LLC dba Internet Brands
