Best Tire to use on 20's
I looking for some opinions on some decent tires to fit on some 20inch T1S's im going semi aggresive not to bad about 4.5" width in the rears...what would be some good quality quiet tires to use..I was thinking about some Toyo Proxes T1R's...if i can get some input about some better tires or cheaper quality tires..thanks in advance
4.5 .... hmm... lip size?..
what about the other wheel specs?... |
20x9.5/10.5+15 all around
nitto invo
^^^ would running these at 245/35/20 & 275/35/20 or 245/30/20, 275/30/20 be better????? which size would stretch them more...well let me rephrase that...what size is more ideal for the wheel specs im using????
^^ This all depends on your offsets and how much of a stretch you actually want.
On top of that, it also comes down to if you want a small, true, or large stretch. Need more info before I can suggest anything. |
245/35/20 - 275/35/20 255/35/20 - 285/35/20
no stretch.... |
Im running the Yokohama S-Drives and I'm on my second set. Cheap price and good ride/quality.
Hankook V12's aren't bad.
Originally Posted by konxeptionz
(Post 5342177)
On top of that, it also comes down to if you want a small, true, or large stretch. Need more info before I can suggest anything. well not to much of a stretch to the point where if i make a abrupt turn tires gone...plus we got potholes n some sh!Tty roads |
Stretch a set of General UHP's. They stretch larger then most tires.
There are some people who run them on this forum and swear by them and how nice they hold up. But I must ask you though. Are you stretching because you need to be able to clear your fenders? Or are you stretching because you just like the look? I read your original post again and you said your offsets are semi-aggressive. What are the offsets for your wheels? This will also help better determine other possible tire selections for you. |
^^^^^ +15
| All times are GMT -4. The time now is 05:04 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
