what size tires would u put on a 18x13 0 offset
I'm trying to find out what size tires to put on a 18x13 0 offset wheel but I want the tire to stretch any ideas???
18x13 holy. Ummm 275/40?
What car u putting them on? G? What wheels |
18x13??!?!!?? Pics of car and wheels or I don't believe it.
405.30.18
Originally Posted by ShanesG
(Post 5424399)
405.30.18
post pix of the wheels and your drop
the tire size depends on the space you need, if you can clear it no need to stretch |
wheels
they are 18x13 0 offset in the rear 6 inches + lip and the front is a18x12 -6 off set for the front which is a 5 inch lip i am putting them on a lexus sc400.......also shane i need some fender work :)...........anyways here are the pics you guys been waiting for they are sitting in the garage waiting to be put on.....if you guys can help me out what size tires can i use for the rear and what size tire for the front thanks
https://i170.photobucket.com/albums/...orkwheels3.jpg https://i170.photobucket.com/albums/...orkwheels6.jpg https://i170.photobucket.com/albums/...orkwheels8.jpg https://i170.photobucket.com/albums/...orkwheels7.jpg https://i170.photobucket.com/albums/...orkwheels5.jpg https://i170.photobucket.com/albums/...orkwheels4.jpg https://i170.photobucket.com/albums/...orkwheels2.jpg https://i170.photobucket.com/albums/...orkwheels1.jpg https://i170.photobucket.com/albums/...workwheels.jpg |
hm a 12 and 13, well since you need to actually TURN i would suggest a 255/40 and the rear hmm 275/40
i believe you need 40 series for 18s i believe shane has a 265/30 on his 12 and is a pretty good darn stretch and you can get away with that up front as well with profile adjusted |
Jesus, wtf???
Holy wow, is this going on stock body? this is gonna be teh nutzzzzz
@ eurodre-so u think I can do 275 rear and 255 fronts?
@ shaneG-well I don't wanna do widebody so I wanna try to fit them on the stock body with pulled fenders....don't u pull fender if so I might need ur help....I'm just waiting on some air ride also.....I was thinkin going 19s but I would go through tires and moore shops just has more 18s in stock....what do u suggest |
honestly i think you would NEED to do those tire sizes but all of this is assuming that you're getting fender work and camber in
it all depends honestly if you're doing it on a stock body then a pull --> flare is necessary and throw down some major camber but tire sizes i predict will be around that size if you want minimal rubbing |
That won't fit a stock body SC without that dirty stretch and like -10!
Ima get them on there some how.....I know a guy that did a 19x12 0 off sey with a pull and some camber so one more inch wouldn't hurt...but hey u would never know till u try it......next question who will mount stretched tired on a 13 inch wide wheel I live in the I.E but willing to drive further to mount them right
several shops might do it
tire central and city tire |
