**HELP** Would this set up clear my BBK's?
Alright guys,
I am currently looking at a wheel set up and wanted to see if these would clear my retrofitted AKEBONO's on my 2008 sedan. BTW these are WORK VSXX in following specs: F 19 x 8.5 (+29et) low disk R 19 x 9.5 (+29et) low disk I know that low disk set up will maximize lip size and offer the least spacing as far as brake clearance. So I was concerned if these would fit over my Akebonos before I pull the trigger. I appreciate the help in advance! Thanks. -Jason |
just email workwheelsusa. Their reps are really nice & knowledgeble. I've gotten their reply within 24 hours.
Thanks for the advice. If no one else can shed some light, I guess I can contact them directly. I might pick these up tonight if someone can help me out though.
try http://www.1010tires.com/wheeloffsetcalculator.asp
and put your current wheel spec and put the above spec. just compare. |
i'm running Vossen cv2 20x9 +38 front.
compare to the above wheel mentioned, inner clearance is 15mm more. It should clear without a problem. becuz according to Vossen, my fronts will clear Akebono. |
Originally Posted by simonsez
(Post 6241436)
| All times are GMT -4. The time now is 04:17 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
