Lowering Springs
I have searched for hours and have learned alot about the differant setups, but I'm still a noob. I have a few questions that I just want to make sure I know the answer to.
I want the most drop possible without throwing my camber too far out of whack. I want to be able to adjust back to factory spec, or within 1 to 2 degrees. I also want a spring that will give me the best performance at the track. With all this, I have a feeling that the z h-tech or the z rsr drop springs might be my best bet. What do you recommend for the most drop staying close to factory spec, and the best perfomance? |
No one knows which of these are the best, or could recommend a better spring for my needs? I'm going to be running 19" 9.5 and 10.5 Volk SF Challenge wheels.
I used the RSR springs for the 350Z........ Have similar setup as you!
TC |
hehehe...1 or 2 degrees outside spec is a HUGE difference! :eek: :D car looks rediculous from the back without camber correction if 2 degrees outside the tolerance..needs to be at least within -2.5 to look decent. (eibachs made the rear about -4 camber with proper toe-in) I'll be putting on my D-Specs in about 2 days. Hope to take her out for a test drive later on this week. :) |
Kenchan,
Please let us know how the D-spec install and test drive goes. I'm sure there are a few people here that will be interested. Thanks mike |
Originally Posted by silver04
Kenchan,
Please let us know how the D-spec install and test drive goes. I'm sure there are a few people here that will be interested. Thanks mike Will do. :) Car's already on jack stands today, waiting for the parts to arrive probably tomorrow. |
