G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   18 inch OEM's????? (https://g35driver.com/forums/wheels-tires/44723-18-inch-oems.html)
tybo971 Feb 17, 2005 07:20 PM
18 inch OEM's?????
Hey guys got a 2003 sedan on the way, can anyone tell me the best place to find some used or new 18 inch coupe wheels???
THANKS
TYBO :D
kenchan Feb 17, 2005 07:37 PM
Before you put them on, do you really want to use +30mm offset on your sedan?
tybo971 Feb 17, 2005 07:43 PM
Sorry newbie, can you explain offset real quick and why would I not want those on a sedan?????
GZire Feb 17, 2005 10:51 PM
Look here:
https://g35driver.com/forums/marketplace-52/
kenchan Feb 18, 2005 12:56 AM
Yep, real quick version is the smaller the positive offset, the closer it
is to the fender. So let say your wheel offset is +45mm. If you put
on a +30mm offset wheel, the wheels are going to be 15mm closer to
the fenders... might even stick out. I saw a few sedans with this
setup and it looked pretty bad imho.
I think people use +38 to +42mm range on the sedans.
© 2026 MH Sub I, LLC dba Internet Brands
