Need help to figure out if these wheels with fit on stock 03 g35
Old 12-05-2016, 02:59 AM
kyle mccarol's Avatar
I have an 03 g35 that came stock with 18x8 with 225 45 on front and 245 45 on the back. I believe it has 30mm off set if I'm correct from factory. So I was looking at these rims I can get a deal on and they are 114.3 so same lug pattern but the rims are 18x9 with a 35mm offset. I know that I should have no problem in the back of the car to fit them but what about the front wheel? will the wheels work with the 1in wider and 5mm more of and offset? If so what tire size could I run in the front and back with my stock suspension?
Old 12-05-2016, 07:43 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Your new wheels should fit fine. The offset change will make room for the bigger rim diameter. On the subject of tires, we encourage new members (really expect but being polite here) to use the search function to find answers to commonly asked questions such as yours........Thx and welcome to the family.
Old 12-05-2016, 02:11 PM
They also have the same rims i want but with a 24mm offset! Would that just stick out to far?
Old 12-06-2016, 06:37 AM
Blue Dream's Avatar
I'm not a coupe expert (assuming you have a coupe) but they should sit fine. I don't think they would even be flush with the fender even with a 9" width. Tire sizes would be your choice, do you want a meaty tire or a little stretch? Wide tires or not so wide? Roll fenders or not? Still lots for you to consider, even things like do you plan on lowering the car in the future and such. A lot of newcomers don't realize the amount of info you need to process to swap out rims.
Old 12-06-2016, 06:40 AM
Cool! And no im not lowering it and i dont plan on rolling the fenders
Old 12-06-2016, 07:07 PM
Blue Dream's Avatar
Then go with the +24 offset, they'll be closer to the fender thus looking a lot better......
Old 12-06-2016, 07:35 PM
Conissah's Avatar
A 9.5" wide front with a +15 ish offset, and an 11" wide rear with +12 ish offset will be flush for a Coupe.
Blue Dream (12-08-2016)
Old 12-06-2016, 08:45 PM
So i should go with the 18x9 and run 225 45 on front and 255 45 on the rear and with the +24 offset ? That sound like it would look good on stock?
Old 12-06-2016, 10:02 PM
Conissah's Avatar
Looks are a matter of opinion, if you like it then that's all that matters. If you want them to be flush, I can tell you the fronts will need ~15mm spacer and the rears will need a good 25mm.
Old 12-06-2016, 10:06 PM
So with those tire sizes and the 18x9 with 24mm offset and put a 15mm spacer and front and 25mm on back it will be flush? Dont have to roll the fenders?
Old 12-06-2016, 10:11 PM
Conissah's Avatar
It will be very close to being flush yes. And if you're stock height you wont need to roll.
Old 12-06-2016, 10:19 PM
But the 225 45 on front and 255 45 on back or different tire size? Thanks for the replys!
Old 12-06-2016, 10:20 PM
Conissah's Avatar
You need a slightly taller tire to keep the VDC (traction control) in check. So those sizes will be just dandy. This is a Coupe correct?
Old 12-06-2016, 10:24 PM
Yes it is a coupe . So i need to get the 18x9 with 24mm offset and the 225 45 front and 255 45 in the back with 15mm spacer on front and 25mm on back? And all that will work on the stock coupe? Cause im about to order all this stuff.
Old 12-06-2016, 10:27 PM
Conissah's Avatar
Yeah man, go for it. I don't wanna be responsible for it tho lol, if you know what I mean. But that will be a nice fitting setup for your car.
