Question RE: Rims
Hello,
I'm a new member - and have owned a 2003 G35 2dr Coupe for about a year now - and I'm looking at putting some new rims on it. I do not know much about the 'offsets', nor how much clearance we need for the OEM Brembos. The rims I'm looking at are: Work - Emotion CR Kiwami Ultimate, with the following profile. [F][!] 5-114.3 19x9.5 +15 [R][!] 5-114.3 19x10.5 +12 Would I need to use a wheel spacer if I followed through and purchased these wheels, or should I get a set closer to the OEM +30? I'm aware this probably has been discussed to death, however, I couldn't find an article relevant to the specific wheel I'm after with the search function. Regards. |
https://cimg5.ibsrv.net/gimg/g35driv...de9074e24d.jpg
This is the style of rim, I have had my guards rolled if that makes any difference. |
You will be fine. Definitely on the more aggressive side but you should be good.
To answer your question, unless you want some major poke and want to run a lot of camber don't get spacers..........
