Wheel Fitment Help
If anyone could shoot me some advice it would be greatly appreciated. I have an 06 G36 coupe dropped on tein s tech springs. I'm going tomorrow to check out this set of wheels and there specs are 19x9.5 +35 offset all around. I've been searching around the forum to see if this set up would cause any problems but can't seem to find any helpful information besides people saying any offset higher than +30 will not look right. I just want to know if I should avoid these before I drive out an hour to check them out.
+35 will be sunken in quite a bit. Use this: https://tiresize.com/wheel-offset-calculator/ and a ruler to determine what you want.
Originally Posted by herrschaft
(Post 7130504)
+35 wouldn't look right. The offset for the coupe rays with no spacers are Front: 19x8+30 Rear: 19x8.5+33 so you can go from there with offsets. There is a big wheel fitment thread that you can get a pretty good idea of what look you'd like
Originally Posted by FreshLikeAG
(Post 7130518)
