Will these rims fit?
I have a 04 coupe with brembos just not sure if these rims will clear the brembos
https://cimg5.ibsrv.net/gimg/g35driv...3aa4cecab1.jpg |
Those aren't rims, they are WHEELS.
The RIM is the circular outer section of the wheel that the tire is mounted on, for stamped steel applications it is then welded to the HUB to make a complete WHEEL. For aluminum applications the entire WHEEL is typically forged from a single cast billet. Unfortunately due to misinformation and ignorance the term is wrongly used in this day. It makes folks look uneducated, I recommend you use the term WHEEL in the future when you are asking about the metal part that the tire is mounted on. This thread has information on the OEM wheel sizes. https://g35driver.com/forums/wheels-...s-offsets.html |
cleric you is wrong, those is rimzzzzz :D
OP I moved your thread to the appropriate place. Please start threads in their proper places in the future. |
