Some help with rims?
I want to put these Ro_Ja rims
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT on my diamond graphite g35 coupe. 19" 8.5 +25 in the front and 10.5 +32 in the rear. What do you guys think? Also do you think i should go with a 9.5 in the front instead of the 8.5? What size tires do you guys think i should get? One more thing, do you guys think the i will rub in the front with the 9.5? Oh yeah, one more. I can't decide if i want to get springs or coilovers. I'm more leaning toward the tein s-tech just because it is alot cheaper than the coilovers i want(the tein flex with edfc). but if i get the s-tech, will it be too much of a drop. Sorry for all the ?'s i just want to make sure that i do it right the first time. So any help would be appreciated. Thanks |
i dropped my ride 1.2 in the read 1'' in the front on eibach pro kits, and it's pretty low as is... my pics are posted, check it out, i doubt u'd wanna go lower than that, cause then ur gonna be smacking everything on the road, but that's juss' my opinion...
It all depends on the offset on the wheels and amount of lowering whether or not you'll rub. At least get 9 inches for the front. Do a search in this section of the forum and you should be able to find out the different tire sizes for the sizes you specified.
Also, you should be able to find out more info on wheels/tires in the "sticky" posts with all the forum member rides. |
