Just got Asanti 20's - HUGE PROBLEM PLEASE HELP
Old May 5, 2005 | 08:19 PM
G352NV's Avatar
Never enough
HUB CENTRIC
Definition: A wheel that is centered or located on the hub by a machined center hole-as opposed to "lug centered" wheels that are located by the position of the lug nuts alone.
http://www.miata.net/garage/hubcentric.html
Old May 5, 2005 | 08:23 PM
G352NV's Avatar
Never enough
Ok one more question, does the wheel have a plastic ring in it? Is it black? If so take that fugger off and bolt that chit on!
Old May 5, 2005 | 08:47 PM
TimW's Avatar
yeah, the bore and rings should be the same on all four wheels. There's no good reason to have it any other way.
Old May 5, 2005 | 10:23 PM
Boon's Avatar
Im sure you paid good hard earned money for the proper product....Make them replace it immediately....dont screw around with trying to fix them.
Old May 6, 2005 | 12:54 AM
kenchan's Avatar
66.1 is your lucky number.
Old May 6, 2005 | 09:19 AM
turbomaxima's Avatar
Man with green rock in Vortech
in 99% positive i don't use hub rings in the front.. i know i use them in the rear because they came with my wheels and i had to swap them out.
are these the first asanti wheels done for a non-brembo g35?
Old May 6, 2005 | 11:38 AM
Sundeviljay's Avatar
NO...I have them w/out brembo's...20's
Old May 6, 2005 | 12:30 PM
astral_essence's Avatar
Sundeviljay - which Asanti's do you have? Did you have any problems fitting them around your hub/bore ring or where they drilled the correct size to begin with?
Old May 7, 2005 | 12:37 AM
Gman2004's Avatar
send them back! They did the same thing to me. I had to reorder the front ones a second time because they would not clear the brembos.
Old May 8, 2005 | 01:52 PM
I have no problems at all with my Asanti's....no problems at all w/the hub/bore....They definitely did yours wrong....just send them back.....DO NOT MESS WITH THEM....You just paid good money, so don't be stupid and ruin them....
Old May 8, 2005 | 03:01 PM
G352NV's Avatar
Never enough
Ill ask again, do the front have black plastic hub rings? If so have you tried to pull them off and test fit the wheel?
Old May 9, 2005 | 12:01 AM
I don't think he is gonna answer....but I didn't have to do anything special to put mine on so I would just send them back if I was him....oh well
Old May 10, 2005 | 11:23 AM
update
Ok to all that answered. Here is the outcome. Took them back and had the bore hole widened to the correct diameter they should have been which was 66.1 (thanks Kenchan). RIms fit on without a problem.
Sundeviljay - what is the lip on your front wheels? Is it 1.5 inches?
I'll post pics of the ride when I get a chance to upload them.
Old May 10, 2005 | 11:50 AM
2.5 front 4 rear
Old May 10, 2005 | 12:01 PM
  #30
which model of Asantis do you have? Mine are only 1.5 in the front.
