G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   What's your drop? (https://g35driver.com/forums/wheels-tires/53496-whats-your-drop.html)
SoCalTed May 9, 2005 10:31 AM
What's your drop?
A lot of folks are asking how much of a drop I have, so i thought it would be fun to start a thread and see what everyone's drops were with what equipment.
To keep it equal, please measure your drop in the following way:
FRONT: Measure inside the fender-well, in front of the tire, where your body/kit wraps underneath. Measure from the ground to where your color starts.
REAR: Again, measure inside the fender-well, behind the tire, where your body/kit wraps underneath. Measure from the ground to where your color starts.
PLEASE STICK TO FORM when responding, then make your comments (just like the product review threads)
Cheers, Ted
YEAR & BODY: 03.5 Sedan
SHOCKS: (OEM) Infiniti Sport Suspension
SPRINGS: Eibach Sportlines
COILOVERS: n/a
TIRES/WHEELS: Dunlop Direzza DZ101s 245/35 and 275/30 & Enkei RP03 19x8.5/19.95
FRONT HEIGHT: 5"
REAR HEIGHT: 6.5"
http://memimage.cardomain.net/member...9_151_full.jpg
SoCalTed May 12, 2005 02:41 AM
{BUMP}
come on guys... It would be interesting to see how close everyone's springs settled.
-T
skeleton_cru May 12, 2005 05:10 AM
Originally Posted by SoCalTed
{BUMP}
-T
I'm confused about where you want us to measure. :confused:
Maybe that's part of the problem? :confused:
GReddySetGO May 12, 2005 12:50 PM
He wants to you to measure the bottom of the front bumper I think and the bottom of the rear bumper, where the rim is at. I don't think thats a good acurate place to measure, because those people with diffrent kits will have diffrent measurements.
The proper way to measure drop is usually the center of the wheel to the fender. Or the center of the fender to the floor.
GXCLUSIV May 12, 2005 04:33 PM
With different aftermarket bumpers, it wont be accurate to compare with everyone. Best to measure top of fender arch to the ground, as mentioned by " Greddysetgo ".
skeleton_cru May 12, 2005 07:17 PM
Exactly! Measure from the ground, through the centerline of the wheel, to the fender. That's the way I always thought you measured ride height.
GReddySetGO May 12, 2005 10:32 PM
Yes, now the problem with doing it that way, is rim size. People with diffrent sized rims/tires will have diffrent heights from the ground.
I guess the best way would be centerline of the fender to the ground, and also post your front/rear tire sizes. So that someone with a diffrent tire size, could take the radius from your tire, and subtract their tire radius, and get an accurate estimate on what their ride height would be with your setup.
© 2026 MH Sub I, LLC dba Internet Brands
