19's are on and i have issues....
i just put my 19's on and i'm having some rubbing issues....i'm lowered on Tein H-Techs and when i hit certain low spots or corner hard i can hear it rubbing....the rears are especially bad.....it is shreading some of the tire on the outside.... do i need to get my fenders rolled or what??....someone please help me out.....
that's what i'm asking
Roll or cut the inner fenders. I would cut it personally. Rolling is a good option, except you're taking a risk in cracking the paint and then you'll have to spend money on repainting it. My advice...take it to a shop that will do a professional job. |
yeah, that is what i'm thinking about doing....i have DPE RS 07's 19x9 in the front and 19x10 in the rear
With a 19x9 and 19x10, I think the lowest you can go is about +25 offset.
It also depends on the section width of the tire. For instance the section with of the 275/35-19 of Pilot A/S is 11". The section width of a Pirelli P Zero Nero M+S is 10.9 (same size). So the tire buldges 0.1" more for the Michelins. This may make a marginal difference in whether you are rubbing or not. It sounds like you have more rubbing than that, so you probably have an offset problem. |
I think having the right offset means you "Must" roll or cut your fenders... Sounds like you got some nice fitment there... I just used a Dremel to grind off what I needed to... Rolled my fenders on my Lex and the paint cracked... I was pretty careful too...
Try to send back the rear wheels and exchange a couple of new ones $1500 OR ask DPE to pay your fender rolling $70 ;) |
Originally Posted by BrianlG35C
Who did you order your DPEs from? :confused: They should of given you the right offsets for your G with or without Brembos to fit properly without rolling or trimming your fenders.
i didn't order them from anyone....i bought them from a guy off here and he ordered them....they are set up to clear the brembos but i don't have brembos on my G...does that make a difference???..... |
Sounds like your got a nice aggressive stance. One thing to remember when not using a fender rolling machine is to make sure the paint is heated so it stretches more. Of course there is only so much it will stretch before eventually cracking. A heat gun does work wonders when using the old baseball bat.
I woudl suggest you pay a little more and get it done professionally with the right tools. You already forked over so much for the wheels, just spend a little more and get them to fit nice and snug. Post some pics too, i d luv to see this. Oh yeah, watch out for potholes ;) |
yeah, i'm having someone do it for me...there is no way i would attempt to do this on my own... i would jack that all up for sure....they actually have a fender rolling machine???....it's crazy cause i went to a body shop here and the guy told me that they wouldn't do it and he would be curious to see how everyone else is doing it.....
| All times are GMT -4. The time now is 08:16 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
