DIY: Shock Sensor In Cabin
Old 07-30-2008, 04:27 PM
IP37's Avatar
anyone have any thoughts on adding both a shock sensor and a tilt sensor?
and has anyone tried this on an 07-08 sedan or g37?
i have the g37 repair manual and i've looked through it a little to find what wires i may need to look at, but all I really found was one wire labeled as "Anti theft horn relay control"
Old 07-31-2008, 12:13 PM
SFLG35's Avatar
FGC President
look for the trunk pin wire. thats what we are using.
Old 03-18-2009, 04:07 PM
DcmaN's Avatar
Ravezzzzz, my bcm looks exactly like yours, and I have a 2006 G35 coupe, I'm trying to finish my alarm install, but I cannot find the door triggers in the bcm!!! They simply are not there I tested every wire. Can anyone help?
Old 03-18-2009, 04:30 PM
WILLIE BEANS's Avatar
subscribed and pmed sflg35 ..
Old 06-04-2009, 02:16 AM
Skyfox16's Avatar
I am really interested in finding out how to add a tilt sensor and impact sensor to my OEM alarm on my g35 sedan but none of the pictures are showing up from the old posts... any help??
thanks!
Old 06-05-2009, 04:14 AM
ctk519's Avatar
thanks!
I also need these pictures for my dei 504m
04 sedan
Old 06-09-2009, 01:04 PM
DrTomSlick's Avatar
Subscribed, looking for as much alarm installation guidance as I can.
Old 06-10-2009, 12:10 AM
thescreensavers's Avatar
Mr.202?
I see no pics in the OP
Old 06-10-2009, 11:48 AM
Boostwhore's Avatar
easiest place is to grab the left door trigger in the door sil area... I could not get my trunk wire to trigger the alarm for some reason so i decided to go with the left door trigger.
The - output trigger on the sensors is very low current and should be attached to a relay to trigger the door trigger wire.
Old 06-11-2009, 04:48 PM
ctk519's Avatar
bump for pics...anyone?
Old 06-13-2009, 08:24 AM
SFLG35's Avatar
FGC President
should be back but if not go here:
http://www.boostedconcepts.com/image...hock%20Sensor/
nevermind
Old 06-13-2009, 08:37 AM
SFLG35's Avatar
FGC President
aight fixed finally
Old 06-13-2009, 01:43 PM
ctk519's Avatar
Thank You!
Old 06-13-2009, 09:58 PM
ctk519's Avatar
Where is the ignition harness? is it in the BCM? I cannot find the white/blue or the black/red wire.
Do i need to follow it from behind the ignition where the key goes?
My BCM looks different than that in the pics. It looks like the one posted as an 04 coupe. mine is an 04 sedan
  #30
Old 06-15-2009, 03:11 AM
ctk519's Avatar
Nevermind, got it all working today. Big props to sflg35 and g35driver.com. Thanks!
Quick Reply: DIY: Shock Sensor In Cabin
