3.5mm input for G35 Coupe.
Curious as ALL of my music is now on my MP3 player, does any company make a 3.5mm aux input cable for the G35? I am having zero luck searching through google. EVERY write up I come across is, "I want to charge and use my iPod", or, "can I use my satellite radio and get an aux input". I have 2006 G35 WITH the satellite radio option, a feature that I will NEVER use, as everything is done through my phone OR MP3 player, again 3.5mm TRS jack. Again, no need to charge anything, no need for satellite radio, or multiple inputs. If not, then perhaps someone has a link to the pinout for the iPod cable? I could just cut the iPod connector off and solder a 3.5mm TRS to the end, that would be easy enough (and cheap, about $8 for the iPod cable). Has anyone done such a thing, hopefully successfully?
It's sticky'd at the top of this forum:
https://g35driver.com/forums/audio-v...ory-radio.html
If you have the actual satellite adapter (not just a button marked SAT) you can add a 3.5mm input for about $2. (Option B in the linked post)
laksjd84
07-24-2015 05:12 PM
