G35 Coupe trunk large enough for 2x12" or 2x10" sub box?
im looking to put a sub box enclosure into the trunk of a g35 coupe,
the dimensions are:
15.8 x 31.1 x 13.1 inches for the 2x10"
16.4 x 33.9 x 15.1 inches for the 2x12"
this is the link to the enclosure
Im pretty sure the 2x12" box doesn't fit, is there any way to fit 2 12inch subs in the trunk?
the dimensions are:
I'm pretty sure you can fit a 12 inch sub on each side of your trunk if you find a 4080 type box. These are nice because you can still drop your back seats when you need the space.
http://www.myg37.com/forums/audio-vi...enclosure.html
Urbanengineer (01-02-2015)
you think this would work out okay?
With having a pair of subs firing towards each other in an enclosed space (without proper signal delay/processing), you're going to have them fighting each other, making poorer quality sound than a single in either position would be. If you can get enough processing in there to have them work together, you're still sealed off from the cabin, putting all that SPL into the trunk lid.
Check out a setup like this: https://g35driver.com/forums/audio-v...ml#post1224216 for better inspiration.
laksjd84
07-24-2015 05:12 PM
vstypicals
07-20-2015 10:55 PM
