leveling
Old Apr 17, 2003 | 06:17 PM
KongzGx's Avatar
leveling
any of you know how to level the headlights and what the level should be.. like where the light cutoff should be in terms of feet/inches/cm/etc?
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Old Apr 17, 2003 | 06:58 PM
Gordgee's Avatar
Administrator
Re: leveling
I think I posted this before:
<font color=blue>Measure and place your headlight 10 meters (393.7")from a screen marked with two lines, one 8.6 cm (3.39")and another 11.3 cm (4.45")below another mark that is the same as the measured center height of your low beam bulb. I just measured and marked a cardboard box and set it on the road.
The light pattern has two distinct horizontal cut-offs, the lower one being to the left. Align the lower cut-off to shine between your two marks, and you're done. </font color=blue>
<font color=green>GG</font color=green>
Old Apr 17, 2003 | 07:47 PM
ryoken's Avatar
Re: leveling
And how would you go about adjusting them if you have the tamper-proof caps installed that are supposed to keep you from adjusting them?
Old Apr 17, 2003 | 08:39 PM
KongzGx's Avatar
Re: leveling
very true... last service appt, they put those caps on...
Old Apr 17, 2003 | 10:10 PM
Gordgee's Avatar
Administrator
Re: leveling
I think that you can still make the adjustment, but it's VERY slow!
The service advisor told me several months ago that the tamper proof caps are quite easy to pop off with a screw driver. Never tried this myself however.
Old Apr 18, 2003 | 02:20 AM
KongzGx's Avatar
Re: leveling
you can make the adjustment very slowly after taking the caps off or w/o taking them off?
Old Apr 18, 2003 | 12:31 PM
Gordgee's Avatar
Administrator
Re: leveling
I think that you can still make the adjustment slowly with the caps on. They just restrict the amount that you can turn the "gears". It takes quite a bit of movement (ie. full turns) to make a noticeable difference in the alignment of the lights.
Old Apr 18, 2003 | 12:51 PM
KongzGx's Avatar
Re: leveling
what's a good tool to use in order to turn the gears? and do you know which way to turn in order to move it up or down?
Old Apr 18, 2003 | 12:57 PM
Gordgee's Avatar
Administrator
Re: leveling
I just used a small screwdriver. Sorry, I can't remember which way raises/lowers it. That's why it's going to be a long and tedious process to make any adjustments while the caps are in place.[img]/w3timages/icons/frown.gif[/img]
Old Apr 18, 2003 | 12:58 PM
KongzGx's Avatar
Re: leveling
there are two gears that touch each other and one smaller one on the back.. which do you turn?
Old Apr 18, 2003 | 01:16 PM
Gordgee's Avatar
Administrator
Re: leveling
I just turned the two that touch each other together. I didn't notice that it changed any thing other than raising/lowering the beam.
g.spot
May 9, 2016 10:54 PM
mbe32
Nov 13, 2015 11:09 PM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
master111
Sep 25, 2015 08:32 PM
JustinMKN1
Sep 18, 2015 03:40 PM
