Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Southbend Clutch/Flywheel Combo + Free Bonus Parts, $1 Shipping, NO CHATTER!!! :)
Old Jan 17, 2011 | 10:41 PM
Coz@Czp's Avatar
New Southbend Flywheel are designed to replace the OEM Dual Mass flywheel. These flywheels also do not chatter like aluminum flywheels, and you still get a weight savings of 5lbs. This Solid Piece 4140 Billet Steel is very durable, and can take a beating from Puck clutches. Total weight including ring gear is 24lbs.
Southbend Clutches come in a variety of TQ Specs, so there is a Clutch out there for everybody. Stage 1-3 are OEM if not lighter feel, stage 4-5 are going to come with a SS pressure plate, and are slightly heavier then stage 1-3, but I could barely feel the pressure difference.
*Each Kit comes with Chromoly Pivot Ball, Stainless Steel Clutch Line, and Pilot Needle Bearing. Shipping is $1 for 3day Service*
______________________________________
Southbend G35 Combo Stage 1 (435 TQ) Rally Clutch / Flywheel Combo
Southbend G35 Combo Stage 2 (486 TQ) TZ Clutch / Flywheel
Southbend G35 Combo Stage 3 (530 TQ) OFE Clutch / Flywheel
Southbend G35 Combo Stage 4 (650 TQ) OFE-SS Clutch / Flywheel
Southbend G35 Combo Stage 5 (800TQ) FE Clutch / Flywheel
Southbend G35 Combo Stage 5 (763 TQ) DXD-B Ceramic 6-Puck Clutch / Flywheel
Southbend G35 Combo Stage 5 (825 TQ) DXD-F Feramic 6-Puck Clutch / Flywheel
Southbend G35 Billet Steel Flywheel VQ35DE 03-06 Sedan, 03-07 Coupe
Redline MT-85 (4-Pack) - G35
Description: Recommended for Nissan 350Z, 370Z, G35, and G37
* Safe for brass synchros, as it lacks the reactive sulfurs found in most GL-5 oils that cause damage
* Offers quicker shifts, perfect synchronizer coefficient of friction * Eliminates notchy shifting, even when cold
* High performance gear protection and longer synchro life
* Recommended for GL-1, GL-3 and GL-4 applications, as well as where most special synchromesh fluids are specified
* Satisfies the gear oil viscosity requirements of 75W, 80W, 85W and motor oil viscosities of SAE 30 and 5W30.
Includes 4 Quarts to complete the Job
Nissan OEM G35 Rear Main Seal
Description: This is a great time to replace your rear main seal, saves time and money if your rear main seal decides to leak after you finish your clutch install.
We also have Southbend Clutch Combos with Fidanza Light Weight Flywheels:
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - Rally Series (435 TQ Cap)
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - TZ Series (486 TQ Cap)
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - OFE Stage 3 (530 TQ Cap)
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - OFE Stage 4 SS (650 TQ Cap)
Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - FE Stage 5 SS (800 TQ Cap)
Old Jan 18, 2011 | 03:14 AM
djfarhan's Avatar
nice prices!
Old Feb 2, 2011 | 12:16 PM
Coz@Czp's Avatar
bump
Old Feb 26, 2011 | 03:55 AM
Coz@Czp's Avatar
bump
Old Mar 16, 2011 | 02:30 PM
FenixL1P's Avatar
Will subscribe to this for future reference. I'm over 104k+ miles on original clutch. I think it is nearing its service life cause after a 2+ hour drive from fresno to sacto, i smell a hint of burned rubber when exiting the car,to which i can initially attribute it to a worn clutch, but not quite sure. I could be totally wrong as it still accelerates and revs normally in all gears.
Old Mar 16, 2011 | 06:57 PM
Coz@Czp's Avatar
Originally Posted by FenixL1P
Will subscribe to this for future reference. I'm over 104k+ miles on original clutch. I think it is nearing its service life cause after a 2+ drive from fresno to sacto, i smell a hint of burned rubber when exiting the car,to which i can initially attribute it to a worn clutch, but not quite sure. I could be totally wrong as it still accelerates and revs normally in all gears.
Damn, I barely got 30K on my stock clutch
Old Apr 18, 2011 | 12:17 PM
FenixL1P's Avatar
So can you confirm the following shipped to 95757?
Southbend G35 Combo Stage 1 (435 TQ) Rally Clutch / Flywheel Combo w/ Bonus and $1 3-Day, $875
Old Apr 18, 2011 | 06:58 PM
Coz@Czp's Avatar
Just as listed, $875 Shipped
Coz
Old May 12, 2011 | 05:04 PM
FenixL1P's Avatar
What about just the southbend g35 flywheel?
Old May 13, 2011 | 03:26 AM
Coz@Czp's Avatar
__________________________________________________ __________
Old Jul 26, 2011 | 09:41 PM
Coz@Czp's Avatar
Bumped!!
Old Jul 28, 2011 | 01:33 PM
Coz@Czp's Avatar
Bump!!
Old Aug 2, 2011 | 07:31 PM
Coz@Czp's Avatar
Bumped!!
Old Aug 5, 2011 | 11:19 PM
Coz@Czp's Avatar
Bumped!!
Old Feb 1, 2016 | 03:35 PM
Mike@CZP's Avatar
Bumped!!
