FS: FS: TURBO 06 Infiniti G35 coupe,6spd,19" rays**TURBONETICS**$8000
Old 10-10-2016, 10:06 AM
goldlifter's Avatar
PRICE DROP! First with the cash owns it. NO TRADES!
FS: TURBO 06 Infiniti G35 coupe,6spd,19" rays**TURBONETICS**00-ykewl4j.jpg
http://www.ebay.com/itm/222261083562...84.m1555.l2649
Up for sale is my clean/clear title 2006 Infiniti G35 Coupe. Body of the car has 153k miles, we were told engine/turbo/clutch have 25k miles. This car runs and drives great with plenty of power and gets compliments everywhere. Has a $4800 Turbonetics turbo kit running at conservative 6lbs of boost but capable of safely running 8lbs(450hp). Engine runs very strong and sounds great(loud, but not obnoxious blow off valve). Engine was rebuilt to stock specs at time of turbo kit, as well as aftermarket clutch was installed. The clutch is slightly stiffer than stock and has a shorter engagement but is still very comfortable to use as a daily driver. Also has a great looking/sounding aftermarket exhaust. Has new tires as well!!!
Only reason the car is priced so low are for the following negatives
1.dash is cracking/chipped in numerous places. Would be an easy DIY project with SEM interior paint 2. drivers seat has small tears 3. navigation screen will pop up when you press the button but won't stay up 4. 5th gear will have a small "chirp" or "crunch" if you shift quickly. If you shift deliberately into 5th at a casual pace, it does not make any sound. 5. There is a slight oil leak on the turbo return line fitting but does not affect drivability and does not drip on the ground. 6. Has a few small scratches as shown in pics but overall, the exterior is in better condition than most cars with 100k miles on them, much less 153k.
The good:
1. Engine runs very strong, no leaks, no odd noises, no blowby from the motor
2. All other gears shift great
3. No slipping from the clutch
4. $4800 Turbonetics turbo kit (BEFORE paying for the install)
5. AEM Boost, Oil Temp and Air/Fuel Ratio gauges
6. Fully loaded with every option (Nav, heated seats, in dash CD changer, premium sound 19" OEM Forged Rays, moonroof etc)
7. New tires
8. Nonsmokers car
9. No rust, Southern car
10. Great sounding stainless steel catback exhaust
Located in Omaha,NE
402 212 2827
Old 10-10-2016, 12:57 PM
bigc's Avatar
Wings Nation
please post a proper verification photo of the vehicle that includes a handwritten note showing your username and date. thanks.
goldlifter (10-10-2016)
Old 10-10-2016, 01:29 PM
goldlifter's Avatar
Old 10-10-2016, 02:13 PM
bigc's Avatar
Wings Nation
gracias!
xxshawnxx
08-13-2016 01:00 PM
MurryV35
Intake & Exhaust
06-28-2016 09:34 PM
bdflyer
06-24-2016 07:29 PM
RINO
01-13-2012 07:52 PM
Quick Reply: FS: FS: TURBO 06 Infiniti G35 coupe,6spd,19" rays**TURBONETICS**$8000
