Wheel fitment question
I found some winter wheels set up on CL but just wanted to see if anybody knew about the fitment. I have a 2006 G35 coupe auto with factory 19". The wheel setup listed is for 2009 Genesis. 225/55-R17 97T Bolt Pattern: 5 x 114. I did some research and it looks like the center bore is 67.1 for the Genesis and G35 is 66.1 so I would just need to purchase hub ring. I'm trying to do much research as possible before making a bid on this set. Thank you in advance for the help.
joedaddy1
07-28-2015 02:58 PM
