Fuel pump not going back inside...
I just took the fuel pump out in an attempt to replace the shutter valve...which was an utter failure because that thing is no where near reachable...
Anyway I gave up on the shutter valve and just wanted to put everything back together but now that fuel pump isn't going in and sitting flush...
I made sure the line connecting the stock fuel supply hose wasn't i the way...and still the pump isn't sitting flush..I've tried this several times now still pump isn't sitting flush to where I can put the bracket and 6 screws....any thoughts?
I drove ttrank's car solo
Received 1,486 Likes
on
Are you sure you're not just pressing down on the pump hard enough? It does have springs you need to compress it a little bit and then put the screws on. I had to do this twice, because the first time I put it in the hose was in the way causing my gauge to act all funky. I ran out of gas in the parking lot once, because of it, lol.
