CV Boot Removal Front PASS side - inner
Hello.
I noticed yesterday that the CV boot is torn and i found a new CV boot kit.
Was wondering how hard would it be to separate the inner bearing off from the axle shaft once the axle is removed?
Would i need any special tools? IS there any trick to this?
The axle is in the good shape and not clicking so don't want to spend 300 for a new one.
Thanks guys
Thanks guys
I replaced my passenger inner boot recently because I didn't know you could get rebuilt axles. It was easy using the DIYs from this site. But I probably paid $20 for the boot and it took me at least a couple of hours to remove the bearing, grease it up and put it back together and you probably don't have the exact boot pliers to crimp the clamp.... if I had to do it over and axles are $66, I'd get a rebuilt one. Then you know you have two new bearings and boots and grease.
The inner boot doesn't actually have a bearing inside.
My pass axle inner boot recently failed. Since I too my merry time and waited 1 YEAR before getting around to replace it, I opted to do the entire axle since it was $50.
Popped the old axle out, slide the new one in...and that was it. No problems since
rezendvous420
05-31-2020 01:26 PM
Nick_M
08-03-2015 11:08 PM
Nick_M
08-03-2015 05:33 PM
