Loose rear license plate...
Alternatively, you could shape some little straps to fit vertically on each end of the plate (in line with where the old bolt holes were), and extend the new aluminum material upwards from the broken point to provide for a new bolt hole in the right location. Likewise, you'd attach them to the remaining bumper material where the plate will cover it up.
This ain't rocket science. Basically, most any competent body man, or even mechanic, could fabricate a simple replacement structure for the plate backing/attachment point. It's not like there is a whole lot of stress or strain on the plate, so there is little need to get all overcomplicated about a fix there.
.02
BTW, you do realize you bumped and EIGHT YEAR OLD thread here, right?
I went ahead and looked up the bumper and did find the actual part you are looking for. It is sold separately, and it costs about $75 if you shop around, which is pretty stupid once you see all that it is. It is basically exactly what I described: A simple cross piece (although made out of plastic!) that is riveted to the main bumper, and has holes drilled at the appropriate place for the license plate.
Here's the part:
(it's number 10 in the diagram shown, and the part number is 85071-JK60A)
(part #11 is for the rivets that hold it on)
http://www.trademotion.com/parts/200...iagram=3841560
Or look at this ebay auction for a whole rear bumper. The first 3 pictures show the piece you are talking about, but if you go to the second page of pics (there are 12 total) you will see that the very last pic is a closeup of that piece you're trying to replace:
http://www.ebay.com/itm/07-08-09-Inf...ts=Model%3AG35
My point is, even the factory part is pretty hokey. You can easily save the money with a few bucks worth of hardware store items and a little ingenuity. Heck, if you bothered to paint it, it could even look BETTER than the stock one.
Not a bad idea at all either, except the plate normally is held off the bumper on pads to keep it from vibrating/rattling/etc. I'm sure it could still be done that way though.
Re: Loose rear license plate
Thanks for the pics. The problem is that now the rivets and part of the new metal strip would show, because the part that broke off ripped part of the base bumper tabs it was attached to along with it, and I would have to extend up to a wider section of the area to span the metal strip in order to get the height correct and to cover up the "empty" area where the rest of the bracket used to be. With the original design, the plate covers most of the black plastic and the rivets, so it really wasn't noticeable (though still cheap and poorly designed).
Great info, thanks again for the help, I may look at ordering that bracket rather than fashion a makeshift one, if I can figure out how to secure it with glue, etc to what is left of the tabs on the bumper..
Thanks! That's an interesting idea. Which type of 3M tape are you thinking of? Will it last and will it stick to plastic? I have about a 2 1/2"x 1/2" flat area on each side that I could affix it to. I could position my plate easily doing that, I would just worry about longevity.
http://solutions.3m.com/wps/portal/3...beS2Z15RR9ZVgl
http://multimedia.3m.com/mws/media/1...df?fn=4218.pdf
bmaca5 (07-26-2015)
I've stuck a whole fiberglass spoiler on for a year now with 1 3 foot length of 3M tape. It feels cemented on there. A license plate will be nothing, and if you use a lot it will never come off. Just clean the area with soap, then rubbing alcohol/water and stick it on and press for a few minutes.
VQ is right those are good tapes, I used .
Funny, I emailed 3M, they say they don't have anything for this application. The tape you used is likely for plastic-to-plastic only, and that may be why they told me they don't have an answer? Meanwhile, on Amazon, I find this:
4.5 stars and $7, may be worth a try at least?
Funny, I emailed 3M, they say they don't have anything for this application. The tape you used is likely for plastic-to-plastic only, and that may be why they told me they don't have an answer? Meanwhile, on Amazon, I find this: Amazon.com: Clear 3M Dual Lock Velcro & Adhesive Kit: Automotive
Ok, you are officially overthinking this!
Do what you want pal, but I swear to god if you ever come across some of that tape I posted, just go ahead and try sticking it between two surfaces and then see just how easy it is to get off; metal or no!
Jeez, you're going to be checking it every year for your new registration sticker anyway.
