weird throttle body reving by itself.
Hey guys I need some help. I was installing the grom audio today. So before I started d going anything I unplugged the negative on the battery. I wired it all up and before installing headunit back together I plugged the negative terminal back up. I tred the car onto the OK position and started testing the grom audio. After aa few mins I decided to start the car to drain the battery due to the audio and light being one. I went to start it and when I went to crank it over the dash flashed and nothing happened. I unplugged the negative again went to start it and it started up no problem. The car ran for 10 mins and I'm guessing after it warmed up it started reving up and down it self. Revs to 1500 and down to 300 and repeats. I tried the all the gypsy pedal dance resets and the car will idle fine for 10 secs and then does its idle jumping jacks.
Any ideas on what happened or what to do next.
Well everything is back to normal, what I ended up doing is the next day after work I ended going through my uprev maps a few times in the car. I made sure it was locked into my performance map started the car it ran for 30 mins and everything seems to back to normal. So either somehow wheni disconnected and reconnect the battery the car assumed the anti theft map. Or the idle relearn I did the night before that I thought didn't register ended up registering
Anyways that my update.
RemmyZero
V36 DIY
04-23-2018 11:13 AM
