06 Headlight housing problem
Old Dec 20, 2005 | 09:40 PM
Asao's Avatar
I recently purchased 06 headlights and noticed that the driver side housing projector is loose. If I push on the back of the projector where the bulb is put in, it is free to move back and forth inside of the housing. So if the housing is shaken, the projector rattles back and forth inside of the housing. All of the mounting screws that are bolted directly to the projector seem to be tight. Has anyone else run into this problem? The other side housing projector is secured and does not rattle at all. Is it possible to fix or should I exchange it? Thanks.
Old Dec 20, 2005 | 10:41 PM
PeteNJ's Avatar
Time to heat those bad boys up and break em open? Then you can color mod the projector!
Old Dec 21, 2005 | 10:34 AM
WRAH's Avatar
WRAH
Since you just bought them I would take them back! Yeah you could open them and color MOD them, but they are still broken and it might be something that you can't fix.
Jusseth
Sep 13, 2020 12:25 PM
wonderizm
Sep 24, 2015 03:09 AM
simperformance
Jul 24, 2015 11:17 AM
attarday
Jul 15, 2015 04:03 PM
