FS: H&R Trak+ DRM 20mm Wheel Spacers - 5x100 / 12x1.25 - 4025561
H R Trak DRM 20mm Wheel Spacers 5x100 12x1 25 4025561 | eBay
OTES: Bolt Pattern: 5/100 - Center Bore: 56 - Bolt/Stud: Stud - Thread Type: 12x1.25 - Spacer Type: DRM - Width: 20mm - Notes: 8
1990 - 1998 Subaru Legacy
1993 - 2001 Subaru Impreza
1997 - 2013 Subaru Forester
1999 - 2004 Subaru Legacy
2001 - 2003 Subaru Impreza 2.5 RS
2001 - 2003 Subaru Impreza TS
2001 - 2003 Subaru Impreza WRX
2004 - 2007 Subaru Impreza 2.5 RS
2004 - 2007 Subaru Impreza TS
2004 - 2007 Subaru Impreza WRX
2005 - 2009 Subaru Legacy
2013 - 2013 Scion FR-S
2013 - 2013 Subaru BRZ
Description
H&R TRAK Spacers 4025561 for a 97-13 Forester, 93-07 Impreza 2.5 RS (Typ GD/GG Sedan/Sport Wagon), 90-09 Legacy (Typ BL), 13-13 FR-S and 13-13 BRZ - Bolt Pattern: 5/100 - Center Bore: 56 - Bolt/Stud: Stud - Thread Type: 12x1.25 - Spacer Type: DRM - Width: 20mm - Notes: 8. View all Scion FR-S Wheel Spacers and Adapters
TRAK+ Spacers
If you’ve ever seen a sleek, European sedan with that oh-so-low street stance and a bulging wheel / tire combo that fits perfectly in the wheel wells, chances are that car was fitted with H&R TRAK+ Wheel Spacers. TRAK+ Wheel Spacers make your existing tires and wheels appear wider by moving the wheel out from the hub, providing both performance and appearance improvements. Whether you want improved handling, increased safety or simply desire your car to make a statement about your individual style, TRAK+ Wheel Spacers can help you accomplish your goal. These are sold in pairs.
Variations
DR Series (10 – 40 mm track widening)
DR Series spacers fit between the wheel and hub, and require longer wheel bolts (ordered separately). Please verify bolt specifics before ordering (taper or round bolt head and shaft length).
DRS Series (10 – 40 mm track widening)
DRS Series spacers fit between the wheel and hub, and require exchanging the existing wheel studs for longer ones (included).
DRA Series (40 – 60 mm track widening)
DRA Series spacers bolt to the hub with special wheel bolts (included) and provide new threaded holes for wheel bolts.
DRM Series (40 – 90 mm track widening)
DRM Series spacers bolt to the hub with existing wheel studs and special nuts (included). Wheel is bolted to new DRM wheel studs.
Features
Hubcentric
Maximizes vehicle track width for great looks, lowered roll center, and increased lateral stability – improved handling
Made of a proprietary aluminum/magnesium alloy (Up to 70% lighter than a comparable steel product)
Hard anodized to ensure a tough, durable finish
Great for use in winter with snow tires and wheels
Sold in Pairs
Description
TRAK+ Spacers
Variations
Features
Hubcentric
Sold in Pairs
