MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Technical (Do It Yourself) > Repairing & Detailing (DIY)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #31
Old 04-08-2009, 11:23 PM
This was a great post fellow g's i had that annoying light on my ride for months and couldnt figure out or find a sure fire way of doing , i tip my hat again the brotherhood of g35driver.com
__________________
[b]2006 AT sport: Injen CAI, Full Stillen dual exhaust, damper brace, ground wires,MREV 2,HKS DLII
  #32
Old 04-17-2009, 04:58 AM
Worked like a charm!
Today I changed my cabin filter and intake filter. Afterward, the air bag light came one. I took everything back apart thinking that maybe I forgot to plug something in. After several hours of checking and double checking I gave up and called the dealer to schedule an appt. Then I found this thread and I tried the second method....problem solved. Thanks!
  #33
Old 05-19-2009, 12:49 PM
2003 Infiniti G35
I did the OP's method and it worked first try.
My question is, if there is a real problem with the airbag system, this indicator light will still light up right? This reset function won't cause the system to "relearn" it's sensors or ignore tripped or faulty sensors that originally caused the indicator light to illuminate?
__________________
03 BS Coupe 6MT, Inven, 06 headlights, AEM CAI, SxExCx grounding kit
  #34
Old 06-30-2009, 01:54 PM
O HELLA JDM's Avatar
2005 Infiniti G35
Send a message via AIM to O HELLA JDM
Quote:
Originally Posted by SFLG35 View Post
this is a little easier
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
this worked like a charm!!! ****ing called kearny mesa dealership, he was telling me ohh for us to check it, it would cost 125. i was like im under warranty still, but he goes since u took out to seat to clean the car itll be your fault, i was like wow, WTF, FCUK u,
good thread!!!
__________________
IONIC Official Sponsor of SDGz
Nismo / Advan / Project Kics / Impul / Data / Tein / VIS / Invidia
Install Projects
  #35
Old 07-03-2009, 06:00 PM
Thumbs up Airbag light blinking
Quote:
Originally Posted by DREPDOM View Post
Yep, worked perfectly for me!!! Repeated 3 times. Thank you guys..
This method worked for me too, thanks ! I recenty had to have the drivers seat removed on my '04 G35 sedan to replace the tracks & plastic gears because the seat would not move up anymore. Gear on right side was stripped. Once the seat was replaced & installed the light started blinking.
  #36
Old 07-16-2009, 03:44 AM
Mahalo for having this thread. I was about to go to the dealer but found this. Thanx alot, ur a life and money saver.
__________________
On Going Project [Installed parts]Stage 3 Clutch/Flywheel, JIC Spartan DE type 1 SUS n' Stech. [NOT yet installed] 60mm Triple A pillar gauge pod,Defi Amber Boost, EGT, Oil preasure, seibon TS.[Other Toy] 05' GSXR1000 with PwrCmndr and HR1 Shorty
  #37
Old 07-16-2009, 02:16 PM
Awesome, thanks!
This method was simple and easy.
Also, thanks to g35man04 for starting this thread.
  #38
Old 07-25-2009, 08:37 AM
BKZJAYY718's Avatar
MYG35IZSICK - AIM
2003 Infiniti G35
Send a message via AIM to BKZJAYY718
Will do this in the morning
__________________
"ME I'M FROM THE APPLE. WHICH MEANS I'M A MAC. SHORTY A PC, SO SHE LIVES IN MY LAP" AIM- MYG35IZSICK
  #39
Old 07-25-2009, 04:02 PM
BKZJAYY718's Avatar
MYG35IZSICK - AIM
2003 Infiniti G35
i called Kearny Mesa Infiniti they charged me $125.00
Thanks guys
__________________
  #40
Old 07-28-2009, 06:32 PM
Send a message via AIM to ITSAGTHING
Quote:
Originally Posted by Antipd32v View Post
I have an 04 G35x and today I replaced the cabin air filter, Well like an idiot I did not disconnect the battery. After I finished I drove down to get the car washed and I noticed my airbag light was flashing, I did this and BAM no more air bag light. Thank you sir.
Mine did the same thing! Replaced the cabin filter and it came on! Why is that? Well its fixed now!
  #41
Old 08-13-2009, 12:32 PM
bkceazG35's Avatar
2004 Infiniti G35
Send a message via AIM to bkceazG35
Does this reset work even after replacing an airbag? Or do you still need to buy the airbag diagnostic module to clear it?
  #42
Old 08-16-2009, 08:18 PM
LightsOut's Avatar
SIETESG
just did this and it worked perfectly...
__________________
OEM style made clean my way
4wisemen
Glance
  #43
Old 08-16-2009, 08:46 PM
worked
just tried it works great
  #44
Old 08-22-2009, 09:20 AM
NNOCENT's Avatar
OVER-BOOSTIN'
Quote:
good thread!!!
Same here. I just got quoted $120 MIN. to clear any/all codes.
They told me I probably had the key in accessory mode and the radio on, and I pulled the seat to clean the carpets (which I think is true)
This thread just savced me $120 from the dealership.
I think i'm going to buy a Premium Membership from the savings on this thread alone.
D I Y - F T M F W
__________________
. . . : : : resident N-G-C videographer : : : . . .
  #45
Old 09-10-2009, 11:10 AM
Thanks for the quick & easy fix! (Hope it stays fixed). My light started flashing for no reason at all. Hadn't done anything to the car recently. My dealer told me it would cost $120 to diagnose, and then a MINIMUM of $800-$1200 to fix the problem. He also said that once the light starts flashing, the system thinks the bags have been deployed, and they won't work now in an accident.
So far, I haven't seen an answer to the question several people have asked about....
ARE MY AIRBAGS IN WORKING ORDER NOW since I reset the light?? Does anyone know?
Thanks for all your posts!!
Tags
03, aftermarket, airbag, blinking, coupe, flashing, g35, infiniti, inifiniti, install, light, nissan, reset, seats, seconds
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
