Failed CA Smog. High NO numbers. Any suggestions?
It would help if you post your actuall smog numbers. If you are only off by a little get some "Gauranteed to Pass" Fuel additive at any auto store. NOX is usually cause by a lean condition= Running hot. Try to richin it up and retard the timming some if possible which I don't think is since its computer controlled. Intake leaks causing lean conditions and faulty 02 sensors showing false rich will also cause lean runs and high nox. Cats don't usually go bad unless they are real old or have physical damage. Good luck in getting everything fixed.. I'm suprised you don't have a CEL as most cases I stated would cause one.
Damn, sorry for trying to help out.. it was late and the numbers aren't exactly below each category. Was wondering why the hell there were so many... AHahah, anyway glad you got everything worked out. Kinda suprising cats had to be replaced. I hope its not going to be the usual for our cars...
hey guys...searched and found this thread...my car also didnt pass because of the same reason as G35pm. my reading is in the 900s. the smog guy was talking about the car running hot..what could it be? the only parts i have on the car are k&n filter, ground wires and stillen cat back...please pm me if you guys get a chance..thanks
Might be your cats like G35pm, I was able to pass fine with similar mods. You might want to try doing a tune up and make sure your cats are heated up before you preform the test.
About your car running hot, its prob an issue with the cooling system, can't tell you what it is but you have to diagnose the problem one part at a time.
#30
