Tokico D-Spec Springs & Shocks
Old Jul 31, 2005 | 10:14 PM
sin4me's Avatar
Seems like a lot of people are using the Tokico D-Spec shocks, but what about the springs? Anyone have 'em? I recently found these available on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
They also have a set available for the 350z:
Thanks.
Old Aug 1, 2005 | 07:53 AM
Benj's Avatar
Will let you know in a week. I just ordered a set. Got them from Everythingg35.com. They were 499 plus shipping.
Old Aug 1, 2005 | 04:00 PM
sin4me's Avatar
Nice, did you get the ones for the g35 or 350? also, any info on spring rates? and if they are linear or progressive? thanks!
Edit: it looks like what is listed on everythingg35.com is just the shocks, i was asking about the tokico springs. i just placed a call to tokico to try to find out the above info, they are supposed to call me back in case anyone else i curious. i know a post was made about the subject a couple months ago, but doesn't look like anyone obtained that info.
Old Aug 1, 2005 | 05:00 PM
sin4me's Avatar
Well, I just got a call back from Ray with Tokico and he gave me the following specs:
G35 - DSK507 - 240f/300r - Linear Springs
350Z - DSK512 - 375f/375r - Linear Springs
The spring rate on the G35 seems way low, I asked him again and he said that was the info he had, so maybe the ones for the 350 would be the way to go. Both are suppsed to lower 1.2inches, but if you put the one from the 350 on it would be like 1.7 correct? Anyone care to give their opinions on how well this setup might work? Thanks
Old Aug 2, 2005 | 12:15 AM
ymisotall's Avatar
I have an 05 Sedan and I bought my Dspecs (for the 350z) from Creative for $495 shipped. I also have 04 350z springs which I bought for $75 shipped. The new suspension rides great. It's a 1 inch drop all around and it's definitely noticeable.
Old Aug 2, 2005 | 02:05 AM
dklau33's Avatar
sin4me.. good job on the info. I'm not surprised the G spring rates are that soft. I'm sure it was done for comfort reasons since that is equated with luxury cars. The Z spring rates seem good but when used on a G coupe would be pretty low and would make a sedan drop about 2+ inches. Way too low for my tastes.
Old Aug 2, 2005 | 03:55 AM
sin4me's Avatar
Yea, very low for a sedan, but maybe good for a coupe. Anyone care to comment on how much bodyroll transfer there would be to the front or back? Thanks.
Old Aug 2, 2005 | 02:40 PM
dklau33's Avatar
Well according to my math if you have already have the original OEM sport springs (314/342) and are using the 350 Dspec springs you are transferring 9.8% roll stifness to the front. With the revised OEM sport springs of (314/427) you will be transferring 31.6% to the front.
Old Aug 2, 2005 | 02:51 PM
sin4me's Avatar
Weird, I just finished doing the math when I came across the previous reply. I have the original sport OEM suspension (314/342) and came up with the following numbers:
Tokico D-Spec G35 Springs (linear)
240/300 F-30% R-14%
Transfer +16% roll stiffness to front
Tokico D-Spec 350Z Springs (linear)
375/375 F+19% R+10%
Transfer +9% roll stiffness to front
Of course, I suck at math so feel free to say how i screwed up, lol.
Old Aug 3, 2005 | 11:22 AM
Gsedan35's Avatar
Very interesting and disappointing at the same time. At 375lbs that's now the stiffest known linear lowering spring in the front* for the G or Z. But, why did they have to give it a 1.2" Z drop, meaning a 1.7" G35 coupe drop and gulp,....a 2.2" sedan drop oh well for those of us that don't want to be dropped that low, pay for expensive alignment fixes or have a ton of bumpsteer.
Not really surprised on the coupe rates, we see the aftermarket all over the map on these car's rate wise, just another case of the same. Thankfully we know that the shocks themselves are really good.
*Nismo T2 springs remain the stiffest at 625/700
Old Aug 3, 2005 | 02:25 PM
dklau33's Avatar
If that Z package had a milder drop on the sedan I'd be all over those.
Old Aug 3, 2005 | 04:07 PM
kenchan's Avatar
knowing how bad the S-tech's rear linear 274lbs/in was, the 300 sounds
just as bad. 240 on the front... very bad move by Tokico.
Old Aug 10, 2005 | 06:30 PM
BbyG35's Avatar
kenchan... Which model D-specs did you go with? For the G35 (DSP-7) or for the 350Z (DSP-9) ??
As from my sig, I'm running Hotchkis Sways with Eibach pro-kit springs -- I'm thinking because of the drop you are probably using the 350Z Tokico's.
Your help is appreciated.
Old Aug 10, 2005 | 06:41 PM
kenchan's Avatar
Im running the DSP-7's
Old Aug 10, 2005 | 08:00 PM
BbyG35's Avatar
Are there any issues with bottoming out like the stock shocks with your setup?
I've experienced bottoming out to the stops a few times and I thought the 350Z ones would be shorter travel. If you have installed the G35 ones without problems then I'll probably go with same setup.
Any one else running DSP-7's with Eibach's on a sedan with no issues??
Thanks again kenchan for your help!!
