View Poll Results: Vortech and TN Oil Return Poll. tap block or use spacer?
Vortech: Tapped the block
34.78%
Vortech: Used an oil pan spacer
39.13%
Turbonetics: Tapped the block
13.04%
Turbonetics: Used an oil pan spacer
13.04%
Voters: 23. You may not vote on this poll
Vortech and Turbonetics Owners: Oil Return Poll ????
Old Jul 20, 2006 | 12:02 AM
QuadCam's Avatar
how many of you tapped the upper pan? how many of you used an oil pan spacer (aam, jwt, etc)?
Old Jul 20, 2006 | 12:07 AM
jimk's Avatar
i have the 1" spacer and tapped the oil pan higher up
i have the one inch spacer and the pan is tapped higher up. you happy with your vortec?
jimk
Old Jul 20, 2006 | 12:11 AM
QuadCam's Avatar
Vortech doesn't ship the Revup kits until Friday the 21st. I am just "getting my ducks in a row." I definately enjoyed the other Vortech kit I had on my Cobra (536 rwhp / 460 rwtq @ 10 psi non-intercooled)
Old Jul 20, 2006 | 01:50 AM
caskyline's Avatar
Former Vendor
I have the pan spacer.I still taped the upper pan.Tapping into the spacer is not a good idea.It will not let the oil drain properly.
Old Jul 20, 2006 | 04:29 AM
sentry65's Avatar
I used an APS pan with my vortech - not listed in the poll
Old Jul 20, 2006 | 09:37 AM
QuadCam's Avatar
the APS pan would fall into the "spacer" category due to the low oil return location.
Old Jul 20, 2006 | 07:15 PM
booger's Avatar
Tapped the upper pan . No problems what so ever . I dont really see a problem doing either . The blower and the ST sit higher than the oil level . And if the return line is ran straight down , it should drain back with no problems
Old Jul 21, 2006 | 11:59 AM
narkotic's Avatar
Thats what I figured booger, however my buddy that I sold my Vortech to decided to try the JWT spacer and it's not draining correctly. The oil backs up and gets into the intake and the car is bogging.
Old Jul 21, 2006 | 12:40 PM
QuadCam's Avatar
that doesn't make sense.
the air side of the vortech should be totally sealed from the gear side. even if the gear side was totally filled with oil, it shouldn't be leaking into the air side of the blower. your friend's vortech may need to be rebuilt. It sounds liek a bad seal (or something similar)
Old Jul 21, 2006 | 01:20 PM
booger's Avatar
I would have to agree .
Old Jul 23, 2006 | 01:56 AM
narkotic's Avatar
Good point...
It was just rebuilt, well, the screw broke that held the cog to the blower.. I'm assuming during that time it was rebuilt. Knowing vortech probably not.
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
CV35Driver
Sep 15, 2015 05:09 PM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
UT G35
Sep 3, 2015 03:58 PM
