got H&R springs
Old Oct 2, 2007 | 11:36 AM
WILLIE BEANS's Avatar
got H&R springs
edit these are lowering springs..
edit : first off their h&r springs (#53050) made for a 350z ...
lowers a 350z 03-and up
1.3 front 1.0 rear
now im not sure if its a good idea to just mount them on with the stock struts ..
i hear its ok .. to use them on stock struts
i hear it will kill your stock struts in a few months ..
eventually i was thinking on koni yellows or billsteins
what to do what to do ..
wait till i get new struts
go for it and replace stock springs ..
help me out guys ...
Old Oct 2, 2007 | 11:43 AM
jonE5's Avatar
from what i hear if you have sport suspension you will be ok
I have also heard that if you get shocks from a coupe or 350z it will be even better due to the shorter shock stroke.
Would be a cheaper option than the koni's
Have you mounted them yet? What model name H& R's is that?
I hear that when doing Z springs add .5" to the drop
so it would be like 1.8" in front and 1.5" in rear
Old Oct 2, 2007 | 11:48 AM
az1anbeethoven's Avatar
^^no, stock Z springs give the sedan a 1" drop...
Old Oct 2, 2007 | 11:54 AM
sorry i didnt post that these are lowering springs
1.3 front 1.0 rear lower on a 350z 03 and up ..
Old Oct 2, 2007 | 12:00 PM
NJlakeshoreG's Avatar
Got These On My Coupe..same Ones...and After About 8 Months The Stock Sport Struts Are Done..bouncy And Crappy Handling...i Went With Tokico Hp's...great Price And Great Product!!!
Old Oct 2, 2007 | 12:54 PM
FlyingLumpia's Avatar
Talk to Da Mayor he has them on his sedan and what I remember he has z struts/shock. I would get the revised struts/shock, also look on my350z.com for maybe some tokico d-specs or koni. Find them alot cheaper than new.
Old Oct 2, 2007 | 12:58 PM
yeah before purchase he let me know these would be good ..
his ride height is sick .. i cant wait ..
im just curious as to my options .. you know ..
Old Oct 2, 2007 | 01:09 PM
be safe than sorry, i would get some new struts/shocks like the d-specs...I think there are alot of vendors on this forum selling them for less than $500 shipped...GL
Old Oct 2, 2007 | 02:41 PM
and that would be for all four sides right ??
Old Oct 2, 2007 | 02:49 PM
yes all 4
Old Oct 3, 2007 | 02:13 AM
Gsedan35's Avatar
1.3 front 1.0 rear
Having tested 350z Tokico D-spec springs with Koni's and tracked how limited the amount of shock piston stroke was even with MUCH shorter cut down Koni progressive soft bump stops. And they don't drop as much as the H&R's your running 1"/1". Do something as quickly as you can to kick your oem sedan shocks to the curb. If the Koni's I was running would have had the ability to adjust more then just rebound control, I might have been able to make things ok. So, in your case that rules out Bilstein's too. The only choice I would go with would be D-specs ment for the Z, they are double adjustable for rebound and compression dampning. Knowing what I know about shock travel issues, I have Truechoice phase IV front shocks with shortened bodies and piston rods. Getting the bump stops way too envolved in everday wasn't cutting it.
Old Oct 5, 2007 | 10:53 AM
wow i would have never though of that ..
see thats why i love this forum ..
wow thats awesome ..
so your saying i should get d-spec's made for a Z .that are double adjustable ..
il get right on it
thanks alot dude .. gsedan35
Old Oct 9, 2007 | 02:51 PM
Gsedan35
Il Buy You A Beer ..
If Your Ever In N.y.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
