New Kinetix Manifold installed with pics.
Old May 19, 2005 | 10:01 PM
G352NV's Avatar
Never enough
Ok just took her out for a ride. Did a couple quick runs and the car seemed to lag a bit. Didnt seem to have as much pull. After the runs I checked my air/fuel and at WOT it was at 9.8, before I was at 10.5. My car REALLY needs a good tune! I should be at 11.5 at WOT. SO the Jury is still out. I guess Ill have to report back after my Dyno tune.
Attached Thumbnails New Kinetix Manifold installed with pics.-picture-1103.jpg   New Kinetix Manifold installed with pics.-picture-1104.jpg
Old May 19, 2005 | 10:11 PM
RaleighNC's Avatar
There are going to be alot of threads posted about this over the next few weeks.
Andy (Mcduck) over at my350z just got his too so I look forward to hearing everyones results before I make my decision later this summer.
Looks the best though in my opionion.
Old May 19, 2005 | 10:12 PM
G352NV's Avatar
Never enough
Yeah looks hands down! I just hope that my tune will show good results.
Old May 19, 2005 | 10:22 PM
RaleighNC's Avatar
Fingers Crossed!!! I am planning to get everything installed at once so I only have to tune one time.
Do you actually work at a shop or something? You remind me of Sharif ( http://www.forgedinternals.com ) New parts everywhere!
Old May 19, 2005 | 10:27 PM
G352NV's Avatar
Never enough
Naw, Im just mod crazy! Im waiting on hella parts to come in! New exhaust to get rid of this JUNK Injen exhaust. JIC Coilovers, and Camber arms.
Old May 19, 2005 | 11:18 PM
Gman2004's Avatar
subscribing
Old May 19, 2005 | 11:27 PM
Vic's Avatar
Vic
Does tunning only applys for FI cars, or does NA cars need it too?
Old May 19, 2005 | 11:29 PM
Gman2004's Avatar
Pretty much for FI cars. If you are N/A and have all the bolts on you can get Technosquare to flash your ECU. This will correct you a/f ratios to optimize your hp.
Old May 20, 2005 | 12:20 AM
Wicked_limitz's Avatar
looking good, get some video clips up!!!
Old May 20, 2005 | 06:14 AM
accordfreak's Avatar
did you have your car dynoed before?
It would be interesting to see the before and after numbers.
Old May 20, 2005 | 09:29 AM
Rookie84's Avatar
NA cars need tuning as well, which TS ECU flash does for you. However, you will see more power from custom tuning because every car is different, although the gain will be minor in NA form.
Old May 20, 2005 | 09:31 AM
Rookie84's Avatar
Hmmm... that's weird. If anything, it should let more air in which will result in higher a/f ratio. Maybe the ECU is doing wierd things. Can't wait to see the final results after tuning!
Old May 20, 2005 | 09:34 AM
Gman2004's Avatar
Well most posts I have read of guys adding piggy backs to N/A motors has neted pretty minimal gains if any. NA cars need tuning but has not been figured out on this car only to optimize hp. The cars already comes tuned from factory so it does not need any more. I think that is what the original poster was asking about....if the car from factory needed tuning.
Old May 20, 2005 | 10:46 AM
madchef's Avatar
Well, at least it's nice and shiney
