Problem
Old Aug 24, 2008 | 02:55 PM
titan13qb's Avatar
Problem
so i was driving last night and i was wearing sandles and i suddenly felt a few droplets on my feet from around the break and gas pedal area...this cant be good any suggestions
Old Aug 24, 2008 | 05:41 PM
AesonVirus's Avatar
Where did it come from? Have you found the source?
How humid is it in OK? Could it be nothing more than condensation from the A/C vent?
Old Aug 24, 2008 | 06:29 PM
titan13qb's Avatar
its humid as heck...so that has to be it..thanks
Old Aug 25, 2008 | 09:14 AM
snowcrossmxz's Avatar
next time it happens, inspect the type of fluid that hit you, thats usually a dead give away of where its coming from.
Old Aug 25, 2008 | 11:30 AM
LiquidGx's Avatar
Fluid on your feet is usually one of two things, brake or clutch.
Old Aug 25, 2008 | 03:28 PM
NationsMostWanted's Avatar
yup...so is it water or something else? i would check the brake and clutch master cylinder if thats the case.
Old Aug 25, 2008 | 08:19 PM
kool_yaar's Avatar
He has automatic so that rules out the clutch i think it might just be some condensation, but best check it out.
Old Aug 25, 2008 | 10:14 PM
AesonVirus's Avatar
Also note that a brake fluid issue would leave traces on the carpets.
I'd bet a nut that this is a condensation issue.
***Note***
This is the second time this week that I have bet a nut. Good thing I've been right so far... and good thing I got two.
Old Aug 25, 2008 | 11:02 PM
oh i didnt know if he was 6 or 5AT
Old Aug 26, 2008 | 09:45 AM
fecurtis's Avatar
It's condensation. Ever car I've ever driven in with the A/C blasting in extremely humid weather will do this.
Perfectly normal.
Or perhaps it's just battery acid. Either way, its harmless.
Old Aug 26, 2008 | 10:00 AM
sredish's Avatar
drill a hole in the floorboard so it'll just run out....
Old Aug 26, 2008 | 10:48 AM
^ha
Old Aug 26, 2008 | 11:11 AM
LiquidGx's Avatar
Condensation on what? The core is on the other side of the car...
Old Aug 26, 2008 | 11:43 AM
paulg35s's Avatar
It's water leaking from the holes when you were mounting the fake intercooler.
Old Aug 26, 2008 | 05:31 PM
ugaexploder's Avatar
haaaaaaaahahaha, good one paul hahaha i tried to find that thread...the mods must've deleted it
