Solution for throttle response problem?
Old Aug 25, 2008 | 10:27 AM
ON_6MT's Avatar
Hi all,
I have an 07 6mt, and like many it has the throtle response issues, ie not smooth, often hesitates, and my dealer keeps telling me they have no ecu flash for the 6mt models.
Anyway, i was washing the car this weekend and decided to pull the mufflers off, as i've done it briefly before to see how it sounds. Been driving the car without them for the past 2 days and i've noticed that the throttle response is much improved, its quick to respond and has very little hesitation issues. I wonder if remvoing a bit of back pressure helped things out. Also the car sounds really quite good, as if there was an after market exhaust on the car.
Just thought I'd share
Old Aug 25, 2008 | 10:34 AM
Texasscout's Avatar
There is a new gizmo in the current issue of Turbo Magazine. It is a "throttle response corrector". Give it a look see.
Old Aug 25, 2008 | 11:22 AM
G35Now!'s Avatar
Moderation-free
There's a TSB for it, you should be able to search for it.
Old Aug 25, 2008 | 11:34 AM
ON_6MT's Avatar
most recent one i could find was
http://2007.infiniti.g35x.googlepages.com/ITB08-017.pdf
and its only for AT not the MT and the dealerships wont do anything.
Old Aug 25, 2008 | 08:08 PM
kool_yaar's Avatar
Hey man i have the MT as well and i got my throttle response update done about 6months+ ago and have been happy ever since, the dealer is just being lazy or ignorant, i cant remeber the TSB number but will try to find my service sheet tomorrow.
Old Aug 25, 2008 | 08:14 PM
kool_yaar's Avatar
OK just checked its ITB07-045(surpasses 028), its mainly designated for throttle fluctuations during cold temp, but trust me with this update the throttle is improved a lot throughout even after eaching regular temps, hope it helps.
Old Aug 27, 2008 | 11:56 PM
RCK's Avatar
RCK
I also have a 6MT and agree with koolyaar that ITB045 makes the throttle response somewhat smoother.
Old Aug 28, 2008 | 01:03 AM
KulG35's Avatar
I like get up and go... smoother like a doggish increase before it hits or just more linear in power?
Old Aug 28, 2008 | 11:31 AM
RCK's Avatar
RCK
Good question. I did not make clear that after ITB 045 reflash the 6MT didn't lose the get up and go. Before I purchased my 6MT I had read about the hesitation problem with the throttle but found that it was a matter of where your foot set on the accelerator pedal.
The G accelerator pedal is hinged at the top and thus requires your foot to be either flat on the pedal or, if you toe the pedal, to toe the pedal at the top. Otherwise there is a delay because of the lack of leverage if you toe the pedal at the bottom or middle.
So, yes, more linear.
Old Aug 29, 2008 | 12:20 AM
kool_yaar's Avatar
^ like he said now its more linear and the car has NOT lost its "punch" at all.
Old Aug 29, 2008 | 02:52 PM
ON_6MT's Avatar
I talked to the dealer and they said there is no recall in canada, these recalls are only for american cars?? anyone in ontario get an ecu flash done?
Old Aug 30, 2008 | 12:14 AM
kool_yaar's Avatar
Its not a "recall" its a TSB (technical service bulletin), its not required by law for the dealers to perform these services unlike Recalls. They are only to perform these services when your car show s signs of such behaviour as cited in the TSB, in this case you tell them that you are experiencing flactuation in RPM when cold and you want them to apply TSB045 and you should be ok.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
leo38cheng
Nov 12, 2015 06:49 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
