Show Your Support Become A Premier Member
Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Only Vendor Threads | New Picture Comments | New Profile Comments |
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction > Tuner & Dyno
Sign in using an external account
Register Forgot Password?
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
submit to reddit
Thread Tools Search this Thread Rate Thread Display Modes
Old 02-01-2009, 06:59 PM
Points: 23,839, Level: 94
Points: 23,839, Level: 94 Points: 23,839, Level: 94 Points: 23,839, Level: 94
Level up: 49%, 511 Points needed
Level up: 49% Level up: 49% Level up: 49%
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
2004 Infiniti G35
Motordyne 5/16 vs Blox 5/8 Spacer before,after dyno runs
Hey guys, i did some before and after runs between the two different spacers. These two dynos were done one after the other so the variables didnot change. I did 3 pulls with the blox 5/8 spacer, and then 3 pulls with the motordyne 5/16 spacer. I changed the spacers while my car was on the dyno so that the results would be as accurate as possible.
The motordyne spacer gained more torque and Hp at all rpm ranges. In the midrange, around 4k, the MD spacer gained about 8lbs of torque over the blox spacer, and around 5000 rpm, the md spacer gained around 9 hp.
I was really amazed to see that the md spacer had better gains in the higher rpm as well. Blox was supposed to be most beneficial in the higher rpms, but the md beat the blox in that area as well.
I gained around 2hp, and 4lbs of torque in terms of peak power.
Overall this was well worth doing a before and after dyno. The midrange power is definetly felt by my butt and dynapack dyno. This was my before/ after dyno, which was performed at Church Automotive, Socal.
I have a 04 g35 sedan. Pics of dyno are attached as well. these are pics taken by my iphone so they are not that clear. i will scan it tommorow, and have better pics tommorow. guys if you pick anyhting out that i didnot mention, please let me know. thanks.
The blue line is a dyno with the blox, and the green/red is with the md spacer on.
Motordyne 5/16 vs Blox 5/8 Spacer before,after dyno runs-dyno.jpeg   Motordyne 5/16 vs Blox 5/8 Spacer before,after dyno runs-dyno2.jpeg
Old 02-01-2009, 07:21 PM
lekker_droom's Avatar
2006 Infiniti G35
great info. not surprising but still, beneficial to the community here. well done.
__________________
2010 Audi S5 Prestige
Old 02-01-2009, 07:35 PM
Points: 3,336, Level: 35
Points: 3,336, Level: 35 Points: 3,336, Level: 35 Points: 3,336, Level: 35
Level up: 91%, 14 Points needed
Level up: 91% Level up: 91% Level up: 91%
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
Garage is empty, add now
i went and bought the blox spacer because of the price and after 6months it cracked and the heat made the top of the plenum bake into the spacer...after that i went and bought the 5/16 from motodyne!
__________________
"If you look through your side mirror and don't see your wheels then you need better offsets"
Old 02-02-2009, 11:16 PM
JBF's Avatar
JBF JBF is online now
JBF > SBF
Points: 10,235, Level: 67
Points: 10,235, Level: 67 Points: 10,235, Level: 67 Points: 10,235, Level: 67
Level up: 47%, 215 Points needed
Level up: 47% Level up: 47% Level up: 47%
Activity: 14.4%
Activity: 14.4% Activity: 14.4% Activity: 14.4%
1994 Mazda RX-7
MD all the way!!
__________________
...Never been STRAFED...
Old 02-02-2009, 11:34 PM
Points: 5,466, Level: 47
Points: 5,466, Level: 47 Points: 5,466, Level: 47 Points: 5,466, Level: 47
Level up: 58%, 84 Points needed
Level up: 58% Level up: 58% Level up: 58%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Awesome result as we expected.
Thanks for sharing!
Old 02-03-2009, 12:27 AM
Points: 11,727, Level: 71
Points: 11,727, Level: 71 Points: 11,727, Level: 71 Points: 11,727, Level: 71
Level up: 20%, 323 Points needed
Level up: 20% Level up: 20% Level up: 20%
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
2005 Infiniti G35
Send a message via AIM to tiguy99 Send a message via MSN to tiguy99 Send a message via Yahoo to tiguy99
+ 1!
I JUST got around to installing my MD CITPS over the weekend along with the zTube and K&N Air Filter.
Best Mod for the buck for sure. Here where I live (Northside Chicago) we have Lake Shore Drive better known as LSD which has now become my new playground.
All in all, the car pulls so much more around 3-4.5ish RPM I hit 70 MPH really quick where my car would be around 50 MPH. The butt dyno test passed with flying colors for sure.
I need to get to a real dyno so I can crunch the #s. I will say the mod definitely helped.
+1 for Tony for sure
I think I'm going to end up getting some good gas mileage too now and that's always a good thing too.
__________________
05: IP G35 Coupe Sport: * SOLD *
Old 02-03-2009, 12:34 AM
Skaterbasist's Avatar
Retired SuperMod
Points: 29,631, Level: 99
Points: 29,631, Level: 99 Points: 29,631, Level: 99 Points: 29,631, Level: 99
Level up: 78%, 369 Points needed
Level up: 78% Level up: 78% Level up: 78%
Activity: 8.4%
Activity: 8.4% Activity: 8.4% Activity: 8.4%
2006 Infiniti G35
I merged your threads since you posted two exact threads in different sections.
__________________
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety."
Old 02-03-2009, 01:45 AM
Activity: 7.1%
2004 Infiniti G35
hey thanks dude, i thought it would be better if i put it in the intake and exhaust section, cause more people will look at it this way.
Old 02-04-2009, 05:12 PM
Points: 24,900, Level: 95
Points: 24,900, Level: 95 Points: 24,900, Level: 95 Points: 24,900, Level: 95
Level up: 55%, 450 Points needed
Level up: 55% Level up: 55% Level up: 55%
Activity: 9.8%
Activity: 9.8% Activity: 9.8% Activity: 9.8%
2004 Infiniti G35
Quote:
you're right - it should be in the intake section... it isn’t really about dyno as much as it is about testing two different plenum (intake) spacers.
Henry, it would actually be better suited for anyone looking for this kind of stuff in the intake section.
__________________
Ron Paul is correct.
Old 02-04-2009, 05:20 PM
Jeff92se's Avatar
Red Card Crew
Points: 29,432, Level: 99
Points: 29,432, Level: 99 Points: 29,432, Level: 99 Points: 29,432, Level: 99
Level up: 66%, 568 Points needed
Level up: 66% Level up: 66% Level up: 66%
Activity: 65.3%
Activity: 65.3% Activity: 65.3% Activity: 65.3%
At least you know your dyno guy is accurate. 10/16" is way bigger than 5/16". Even the 8/16" spacer is considered "thick" in terms of "area under the curve gains"
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash
Old 05-11-2011, 10:52 AM
walshtj's Avatar
Points: 4,938, Level: 44
Points: 4,938, Level: 44 Points: 4,938, Level: 44 Points: 4,938, Level: 44
Level up: 94%, 12 Points needed
Level up: 94% Level up: 94% Level up: 94%
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
I know this is an old thread, but I think the information is pretty interesting.. BUMP!
__________________
Motordyne/K&N/GTSPEC/NISMO/NiftyShifty/SxExCx/Gialla/RareJDM/Continental
Old 06-03-2011, 02:55 PM
sexyrob's Avatar
Points: 8,530, Level: 62
Points: 8,530, Level: 62 Points: 8,530, Level: 62 Points: 8,530, Level: 62
Level up: 27%, 220 Points needed
Level up: 27% Level up: 27% Level up: 27%
Activity: 8.9%
Activity: 8.9% Activity: 8.9% Activity: 8.9%
2006 Infiniti G35
none none none none sxyrob
I did the same test and noticed that 5/8 skunk2 made slightly more power than the 5/16 motordyne in the high RPMS.
still dont see how its possible for one piece of material that creates volume can make more power than another IT MAKES NO SENSE... use your heads guys.
Old 06-03-2011, 11:24 PM
Activity: 9.8%
2004 Infiniti G35
^^^ the MD 1/2" makes more up top than 5/16" too... it's not the material its the volume... 5/8" of course is slightly bigger than 1/2" but there is a sweet sport and 1/2" seems to be it (based on extensive plenum shootout testing done years back - as seen on MD website link).
The first spacers Tony was using were 5/8 - then he determined 1/2 was actually more advantageous... and of course later came 5/16 due to slightly better mid... but in the whole of things if you look closely at the data gathered (from many dyno pulls on different cars) the 1/2" gains in upper are by a greater margin than the 5/16" do in the mid... IMO the 1/2" is the way to go and based on the configuration I run (which is more detailed than just specific intake)... I've had very good results.
I do need to remove plenum and do some more tweaks though - some time ago things went amiss a bit (not sure why exactly, but I have my suspicions).
One thing is for certain... 90%+ people boast a specific setup as being "the one" only because they read it somewhere else... not many have actually researched or have done any testing - so for that, I give you kudos... but because of that, I've been turned off and dont bother giving info to people anymore - it has gotten goofy over the past few years...
__________________
submit to reddit
Tags
516, 58, bigger, blox, dallas, dyno, intake, md, motordyne, plenum, spacer, spacers, throttle, versus, video
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
G35Driver.com | My350Z.com | MyG37.com | ZDriver.com |
Everyone's Contact Details
