Results of Eibach Pro kit drop WITHOUT camber kit
Old Nov 26, 2008 | 08:49 AM
bfranks's Avatar
I had my 08 G35S dropped on Eibachs and aligned without a camber kit. I've seen lots of debate on the G35 and G37 boards on if a camber kit was necessary for these springs, so here are the numbers to help you decide. I'm sure some of you could live with the results, but I decided to go ahead and order a kit.
Attached Thumbnails Results of Eibach Pro kit drop WITHOUT camber kit-alignment.jpg
Old Nov 26, 2008 | 09:27 AM
TheIvoryG's Avatar
Not bad actually...anything under 2* I think is workable. I got 15K out of my T1Rs with -1.9* all the way around. Now post pics of the drop!!!
Old Nov 26, 2008 | 11:54 AM
Lemodular's Avatar
How soon after the install did you have it aligned? Did you wait for the springs to settle?
Old Nov 26, 2008 | 12:24 PM
tg1234's Avatar
^ really good question.
tg
Old Nov 26, 2008 | 12:25 PM
bfranks's Avatar
This was done as soon as the springs were put on. The place I had it done at thought they could get it in spec without a camber kit, and agreed to align it for free if it had to be redone after the camber kit was installed. Since there had been questions about these springs without the camber kit I figured I had nothing to lose.
Old Nov 26, 2008 | 12:31 PM
TheIvoryG's Avatar
I would have them check the fronts again after the camber kit is done though...just to be sure.
Old Nov 26, 2008 | 12:35 PM
Cyanide Ride's Avatar
For me, my X was nothing too terrible and just inside spec.
Personally, I waited a week before going for an alignment and the rear settled alot.
About 2000+kms on them so far without any unusual or noticable tire wear.
Old Nov 26, 2008 | 12:36 PM
bfranks's Avatar
I'm still waiting on tires for my rims, so I figure I'll let it sit two weeks or so before I install the kit and have it re-aligned. I figure the fronts will change some, but not too much. I'll post up the numbers after the second alignment
Old Nov 30, 2008 | 11:21 AM
accordspeed306's Avatar
can someone link me to a website with great price on camber kits for 07 sedan sport?
Old Nov 30, 2008 | 11:40 AM
Texasscout's Avatar
This puzzles me, because as far as I know (on 03' to 06' sedans) there is only ONE adjustment, "Toe-in". Are the 08's different?
Old Nov 30, 2008 | 12:02 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
You are correct... Toe only on the front.
Front camber is what it is. (w/o camber kit)
Old Dec 17, 2008 | 03:25 PM
ND#7G35X's Avatar
Cool Emergency Camber Kit
HEY GUYS I REALLY NEED YOU HELP. I HAVE AN 2007 G35X AND IS DROPPED ON TANABE DF210'S. THE FRONT IS 1.7 AND THE REAR IS 1.5. I JUST PURCHASED THE CAMBER KIT BOLTS. AFTER GOING TO NISSAN THEY SAID THE BOLTS ARE TO SHORT. SO CAN SOME ONE PLEASE HELP ME OUT WITH THIS. EVERYONE IS TELLING ME THEY DON'T MAKE A REAR CAMBER KIT FOR THE X
Old Dec 18, 2008 | 02:24 AM
jsmonet's Avatar
-2 or less and you're fine. i don't see any reason to kit it down to anything less than -1deg unless you do all of your driving in a straight line.
also, toe-out in the rear? whyyyy? that'll wear out your tires far worse than any camber issues, and cause the car to be more tail-happy. zero that out all around and be done.
Old Dec 18, 2008 | 07:13 AM
bfranks's Avatar
Again.....this was WITHOUT a camber kit, so there was only so much they could adjust.
I just had it re-aligned after installing the camber kit, and it's much better now. I'm having to run -2.2 camber in the rear to tuck my tires in the fender, but the toe is zeroed out now. I misplaced the sheet, so I'll try to get another copy from the shop to post up.
I can say that I was wrong about the alignment changing much after the springs settled. The rears changed 3-4 10ths in camber and slightly in toe. So I would definitely wait at least a week or two before getting it aligned.
Old Dec 18, 2008 | 10:41 AM
soundmike's Avatar
Which shop did you use? Are their rates reasonable?
Thanks.
