Review: Tanabe Sustec Pro S-OC Coilovers
Old Jan 23, 2010 | 08:32 AM
Q8y_drifter's Avatar
Old Jan 23, 2010 | 02:54 PM
2007BlueSlate's Avatar
You car looks great!!! Couple of quick questions, how much did you lower front and back? and what size rims do you have?
Old Jan 23, 2010 | 04:37 PM
a bit more than 1" front and back. Wheels are 19"
Old Jan 24, 2010 | 05:57 AM
Matchstickman60's Avatar
Looks great. You help me made up my mind. Thanks a lot.
Old Feb 2, 2010 | 05:09 PM
One last question: Do you have any camber kit installed, and how is your tire wear?
Old Feb 2, 2010 | 05:24 PM
nope no camber kit. tires are fairly new so I can't comment yet (5K miles)
Old Feb 4, 2010 | 09:40 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
nice write up
...stickied
Old Feb 4, 2010 | 10:11 AM
Thanks
Old Apr 24, 2010 | 05:00 AM
4p81's Avatar
Exactly how low will these tanabe's allow u to go down(F&R)? And are they pillow top mount, rubber mount, or aluminum plate? I'm trying to achieve the flush,poke, and stretch look and not sacrifice the ride quality. Thanks in advance for my list of questions.
Old Apr 24, 2010 | 07:02 AM
Tanabe says they will drop the sedan -1/8 ~ -2 3/4in Front -1/4 ~ -2 3/8in Rear
These shocks reuse the OEM upper shock mounts.
Old Apr 24, 2010 | 04:33 PM
4p81's Avatar
Thanks! Gotcha...I wonder will that be low enough for the stance I'm going for.
Old Apr 24, 2010 | 04:52 PM
There are pics of these coils on Tanabe's site installed and dropped. It's really low.
Old Apr 24, 2010 | 06:07 PM
4p81's Avatar
Awesome thanks for all the input. Tanabe's it is and out goes my D2 dampner coilover kit I was leaning toward originally.
Old May 1, 2010 | 09:56 AM
Pennywise1971's Avatar
With the 1" drop front and rear are you able to get the camber adjustments back to stock with the factory suspension adjustments, because not being able to rotate the tires with staggered wheels sizes is a big concern. I'm wondering with a minimal drop if you are able to get the camber back to factory settings just using the factory adjustments?
Old May 1, 2010 | 11:41 AM
  #30
I'm actually dropped a little bit more than 1". At this current height, there are some adjustments (camber I think) that I cannot adjust to be within factory specs using the stock camber links.
I read a long time ago that the max drop that you can do without having to buy aftermarket camber links is 0.8", which you can do with the Tanabe's no problem.
