FS: socal:Volk SF-Winning 19x8.5 +24 19x10.5 +29 with tires
They will with a little work. You'll need to flatten your fenders, dial in some negative camber, and run some stretch on the rear tires to get them to tuck, all depending on how low you are dropped. Bump for a set of rims that I really want.
can you send pics of each wheel to lawrencechenmail [at] gmail [dot] com?
i have a 2005 g35 sedan. will these fit as long as i roll my rear fenders? i don't want to stretch tires or go with negative camber.
if you want them to fit, you will need neg camber and run no larger than a 265/30. If on coils, stiffen them up.
as long as you roll your fenders you would be cool when you drop the car the natural camber should be good enough to run them with the tire set up there on right now.
Pics of each wheel to tteague@austin.rr.com please. Very curious.........
